• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    block attribute formulelike this text = right(text;4)
    101 Views, 1 Replies
    10-04-2012 06:48 AM
    hi
    i have a titelblock whit an attribute definition -> filename ->Uppercase
    the result is a full path
    wath i want is just te last 4
    ex  D:\folder\folder\folder\projectname\index0051\filename
    i want the atribute value to be 0051
    can someone help me?
    kris.
    Please use plain text.
    Valued Mentor
    Re: block attribute formulelike this text = right(text;4)
    10-04-2012 12:33 PM in reply to: KrisP007
    In a field in the attribute value, select diesel expression and paste the following
    $(substr,$(getvar,Dwgprefix),$(-,$(strlen,$(getvar,Dwgprefix)),4),4)
    It should do what you want
    Regards Steven Gray
    Setting Out (Joinery Manufacturing)
    Autocad 2013LT
    Windows 7 professional
