• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    chris
    Xref / Layer States Manager Question
    664 Views, 4 Replies
    07-20-2011 11:51 AM
    Ok here you go,
    I have a Xref with multiple Layer States,
    I xref'd it into a sheet with Floor plan Layer States,
    nowi want to Xref it in again with the Ceiling Plan Layer Staes.
    Just to be clear i want the same Xbase Xref'd in a sheet twice with 2 different layer states. how do i do this????
    Please use plain text.
    *Expert Elite*
    Re: Xref / Layer States Manager Question
    07-20-2011 02:28 PM in reply to: chris
    The only way I could think of at the moment is to make a copy of your xref file and have one file with one layer states and the other with the other layer states.
    *Expert Elite*
    07-20-2011 04:31 PM in reply to: chris
    Can you get away with using viewport's layers?
    1. xref onto sheet
    2. create layout viewport1
    3. load layerstate1
    4. from within viewport1's model space, manipulate viewport layers to match model space layers (easy to do with creative sorting and mass matching), thaw/on/unlock all xref layers in model space, save as layerstate1a (or whatever)
    5. create layout viewport2
    6. load layerstate2
    7. repeat step 4, save as layerstate2a
    New Member
    04-24-2012 10:19 AM in reply to: chris
    Attach the base file > rename the attachment in the xref manager to something like XCLG > attach the same base file again > they should be listed individually > repeat as necessary
    You must save the base file in which ever layer state you want it to be attached in prior to attaching each time. Make sure the option "Retain changes to Xref Layers" is checked under "Open and Save"
    Distinguished Contributor
    Retain Changes to Xref Layers option clarification
    11-28-2012 09:00 PM in reply to: dbraden
    The "Retain Changes to Xref Layers" check box option is found in
    TOOLS>OPTIONS>Open and Save>External References.
    Geoffrey Wheeler
    IV Pro 2011 64bit SP2; Win7 Ultimate SP1
    ASUS MB Intel i5-3450 @ 3.10 GHz, 8GB RAM
    ATI AMD Radeon HD 6600 Series, 1GB RAM
