• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    ingertsonj
    Working with templetes for titleblocks
    311 Views, 10 Replies
    02-16-2012 11:12 AM
    Is it possible to insert a second templete into a drawing, so you can have two different titleblocks in layout (paperspace)
    thanks
    Please use plain text.
    Patchy
    Re: Working with templetes for titleblocks
    02-16-2012 11:34 AM in reply to: ingertsonj
    Only 1 template per layout allowed, or you have to insert many DRAWINGS per layout.
    pendean
    02-16-2012 12:52 PM in reply to: ingertsonj
    >>>...have two different titleblocks in layout (paperspace)...<<<
    Copy/Paste from one layout to another layout whatever content you want. Thre is no layout-merge feature.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    Active Member
    ingertsonj
    02-21-2012 09:40 AM in reply to: pendean
    just to let you know I have decovered a wat to have to two diferent Templates in one drawing, it is possible to do.
    pendean
    02-21-2012 09:44 AM in reply to: ingertsonj
    That's never been a problem to do, not what I wrote though.
    Active Member
    ingertsonj
    02-21-2012 09:56 AM in reply to: pendean
    Dean
    My original Message was regarding having 2 different Templates (titleblocks) in the same drawing.
    Other post responded this was not possible, all I am saying is that is is possible to have two different Templates (titleblocks) in one drawing.
    Thanks for your help
    Jeff
    Patchy
    02-21-2012 10:21 AM in reply to: ingertsonj
    READ IT AGAIN
    You can have a millions .DWG insert  into your drawing.
    What I posted was:
    Now, right click on the LAYOUT tab when you're in paperspace, from Template...
    CAN YOU IMPORT 2 TEMPLATES?
    Learn to tell the difference between Template (.DWT) and Title Block, they're not the SAME.
    Active Member
    ingertsonj
    02-21-2012 10:26 AM in reply to: Patchy
    I understand the difference between a titelblock (Drawings) and a Template .DWT.  what I am trting to say is that in my situation I have two different titleblocks that are templates DWTs.
    *Pro
    nestly
    02-21-2012 10:59 AM in reply to: Patchy
    Layouts, Templates, and TitleBlocks.... OH MY!!!   :smileysurprised:
    Patchy
    02-21-2012 11:03 AM in reply to: nestly
    There will be more from Autodesk every year.
    How can we survive
