AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Workaround for vp override?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am still unable to assign a viewport color override to a 3D solid xreffed into the current drawing. Is there a fix yet? The override color shows in the vieport but when executing a "hide" or plotting the object reverts to it's original color. It would seem to be a large enough "bug" to warrant a hotfix
Re: Workaround for vp override?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you use another visual style than 2D-wireframe or legacy-hidden the rendering of the viewport runs in true-color-mode and true color can't be overridden.
So check the setting for the visual-style for the viewport + verify that the viewport is plottet as visualized and not in any other style (or you set this property to legacy-hidden).
HTH, - alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, Vp set to 2d wireframe w/ legacy hidden for plotting. I know it is a bug already, I was just hoping there is a fix available. It seems like it's still an issue. I tested in 2013 and it still happens there too. Keeping fingers crossed for a fix....
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can you upload this DWGs (or similiar ones showing the same problem?
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
All you need to do is create a drawing with two solids on separate layers. Xref that file into another drawing, setup a viewport and apply a vp color override to one of the solids. The display looks correct but if you issue a hide command or plot, the object reverts to it's original color.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
you are right, I can reproduce it (with 2012 output to DWF and PDF) ... and ... at the moment I don't find a workaround.
Have you sent it already to your support-center so Autodesk get's notified about it?
But I can not reproduce the problem with 2013. With AutoCAD 2013 it works as it should. See my drawings plus the PDF-output attached.
Sorry, - alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have not sent it in to support. I had tried on 2013 as well with no luck. I'll have to revisit my effort.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi dmmeehan,
I tested this in both 2012/2013 and may have found a workaround for 2012, which appears to work.
In AutoCAD 2013, I could not reproduce this as Alfred already mentioned it.
In 2012, I was able to plot to PDF with the assigned VP overwrites, by setting the shade plot to Wireframe rather the Hidden. See the results to this here. - http://screencast.com/t/2orBUg8KyGvT
Also see the files enclosed.
Hope this helps.
Martin Langolf
Product Support Specialist
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
To plot it not hidden (as you showed by switching to wireframe for the right viewport) is imho no workaround for a hidden-plot-question/-issue.
Sorry, - alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have several 3d xref attached and this ****in software driving me nuts on the view port colour overrides. just cant override the colours in thge View Port. Dont know when these guys going to streamline the commands to function to what they are designed for. Useless Useless Useless
