• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Distinguished Contributor
    Wipeout in paperspace doesn't cover modelspace entities in viewports
    1194 Views, 5 Replies
    02-16-2011 01:12 PM
    Have a drawing, I go to paperspace and draw a wipeout over a viewport. The modelspace entities shine through even after draworder, etc. If I make a new drawing and do the same thing, it works as intended. Is there some obscure system variable or something?
    Please use plain text.
    Re: Wipeout in paperspace doesn't cover modelspace entities in viewports
    02-16-2011 03:08 PM in reply to: thatcadguy
    Is Plot Paperspace Last checked in your page setup? Not sure if it affects pre-plotted display, but might be worth a shot.
    Kate Morrical
    Technical Marketing Manager
    LT Unlimited
    02-17-2011 05:17 AM in reply to: Kate_LT
    Thanks, I'll give it a shot.
    *Pro
    nestly
    02-17-2011 07:18 AM in reply to: thatcadguy
    According to Lynn Allen, Text Masks (wipeouts) in PaperSpace can not be used to mask Modelspace objects.
    http://lynn.blogs.com/lynn_allens_blog/2011/01/an-autocad-hip-tip-on-textmask.html
    JGerth
    02-17-2011 07:33 AM in reply to: nestly
    workaround could be to create a solid hatch in paperspace  to hide what you don't want to see, and set the color of the hatch to TrueColor 255,255,255
    02-18-2011 07:52 AM in reply to: nestly
    @nestly: Try it, it works in a new drawing.
    Thanks for the solid hatch suggestion, I'll try that.
