• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    Why is this happening?
    236 Views, 11 Replies
    10-10-2012 05:18 AM
    Over the past few weeks I've had a problem recurring and spreading through my drawings.  When I select a block I get a symbol I've never seen and the block will not copy or move where I snap.  It's as if there is some sort of offset in place.  And once an "infected" block touches another, it the next one has the same problem.
    I've attached a screenshot of the unknown symbol.
    Can anyone tell me what this is and how I get rid of it?
    Please use plain text.
    Valued Contributor
    pkolarik
    Re: Why is this happening?
    10-10-2012 06:01 AM in reply to: wkoehler3
    That almost looks like the "constraints" symbol? I don't use them at all, so don't know anything about them. Maybe look into turning constraints off?
    Active Member
    10-10-2012 06:07 AM in reply to: pkolarik
    That is what the symbol looks like, but there are no constraints on these blocks.
    Distinguished Contributor
    imadhabash
    10-10-2012 06:13 AM in reply to: wkoehler3
    it's a PARAMETER item , usually used to locks elements in position.
    Active Member
    10-10-2012 06:20 AM in reply to: imadhabash
    But we've been using these blocks for years over 10 years.  Why would they suddenly have parameters attached to them?  They aren't there when I first insert the block.  And I can have 2 copies of the same block, one has the problem, the other does not.
    And the biggest question, how do I stop this from spreading to all the other blocks in the drawing as it seems to be doing?
    *Expert Elite*
    10-10-2012 06:40 AM in reply to: wkoehler3
    Do you have Infer Constraints turne on?
    Also, notice that it is not necessary to paste to Word.doc save doc attach doc, download doc, open doc file.
    Simply paste to MSPaint and click the Insert Image link above.
    Inventor Professional 2014 Edu 64-bit
    Active Member
    10-10-2012 06:49 AM in reply to: JDMather
    Infer is off.  New issue added on.  Now I select one item to move, but several items move along with it, not to where I said to move, and at different angles.  This is driving me slowly mad!
    *Expert Elite*
    10-10-2012 06:51 AM in reply to: wkoehler3
    Can you attach an example file (*.dwg) here that exhibits this behavior?
    Infer Constraints is off now - was it always off?
    Active Member
    10-10-2012 07:01 AM in reply to: JDMather
    Here you are. It seems to start with the items in red.  The indicated block is one of the problem ones
    Active Member
    10-10-2012 07:13 AM in reply to: wkoehler3
    Try the delconstraint command
