• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    alextsybin5011
    Accepted Solution
    While being panned, a drawing changes its color.
    730 Views, 7 Replies
    09-01-2010 12:20 PM
    Guys,
    When I start panning a drawing in AutoCAD 2011, it immediately assumes a color of the background. Is there any way to prevent that from happening (so a drawing stays as it is while being panned)? Thanks.
    Please use plain text.
    Active Contributor
    randomnewb
    Re: While being panned, a drawing changes its color.
    09-01-2010 01:19 PM in reply to: alextsybin5011
    what element of the drawing is it thats changing color?
    Valued Mentor
    stevenelliott3894
    What you are asking doesn't make much sense. Or, at least, my feeble brain can't make sense of it.
    What exactly is it that 'assumes a color of the background'?
    Are you saying the objects (lines and circles, etc.) of the drawing become the same collor as the background and you can no longer see them?
    Steven Elliott
    When I was a little bitty boy, my grandmother bought me a cute little toy. Silver bells hangin' on a string... she told me it was my ding-a-ling-a-ling!
    Member
    alextsybin5011
    09-01-2010 01:26 PM in reply to: alextsybin5011
    I am working with map images creating pavement marking plans. The background color is currently grey. When I start panning, the map itself becomes grey, too. All I can see is whatever I drew - solid and broken white line and whatever.
    Member
    alextsybin5011
    09-01-2010 01:28 PM in reply to: randomnewb
    The background of the drawing itself. So I am able to see only what I put on it.
    Active Contributor
    randomnewb
    09-01-2010 02:13 PM in reply to: alextsybin5011
    that is not the drawing backround, just fyi. the RASTER IMAGE you have inserted is the object thats becomming transparent, just to clarify.
    im not sure how to maintain images while panning
    Active Contributor
    randomnewb
    09-01-2010 02:46 PM in reply to: alextsybin5011
    http://docs.autodesk.com/ACD/2011/ENU/filesACR/WS1a9193826455f5ffa23ce210c4a30acaf-4eb0.htm
    that should get it taken care of for you, if not let us know
    Member
    alextsybin5011
    09-02-2010 05:17 AM in reply to: alextsybin5011
    It worked! Everything's fine now. The image stays as it was, when I pan it.
    Thank you very much!
