• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Member
    ltombrowski
    Which course should I take?
    270 Views, 7 Replies
    01-14-2012 11:35 AM
    Hey guys.
    I just joined autodesk and need some advice. I'm a student, and I want to learn autodesk courses and I want to know which one to start with.
    Thanks.
    Please use plain text.
    Active Contributor
    CSEnginuities
    Re: Which course should I take?
    01-16-2012 07:18 PM in reply to: ltombrowski
    If you're pretty good with self-teaching or figuring things out on your own, you might want to try that route.  Nowadays there are so many free online resources (you can learn just about anything on YouTube nowadays! Plus don't forget Autodesk University podcasts).  There's also the Autodesk recommended Mastering series books (Mastering AutoCAD, Mastering Inventor, etc.) you can buy.  I know I bought the Inventor and Revit ones and learned BIM on my own, but maybe I had an easier time moving to these platforms because I already knew some form of CAD software, which was AutoCAD.
    Best of luck to you,
    Clara
    Clara
    "A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."
    Valued Mentor
    01-17-2012 05:23 AM in reply to: ltombrowski
    Join AUGI.com (free), go to the Education tab and find the Archived ATP courses. Look for courses like: ATP253 - AutoCAD 101 A Survival Course for Beginners.(2009). Basic classes do not need to be taught in the latest version.
    Member
    ltombrowski
    01-17-2012 03:42 PM in reply to: CSEnginuities
    Thanks for the help.
    So I guess autoCAD would be the one to start with?
    *Pro
    01-18-2012 04:45 AM in reply to: ltombrowski
    That depends on the field you are entering.  If you simply want to get a basic foundation of CAD work and Drafting, then AutoCAD is "good enough", but if you want to get a leg up on your fellow students (ie. your competition) then take CAD courses that reflect the field you want to get into (ie. Civil 3D for Civil).  And keep in mind that the majority of "vertical applications" like Civil 3D, or MEP, etc. run off AutoCAD, so anything you learn in a "basic" course will stil apply to the fancier software.
    Another good tip, get an AutoCAD "Command Reference" book.  It's all well and good to know which buttons to press when, but it's even better to KNOW about the buttons you are pressing, and know the commands that may not have a button to press.
    01-18-2012 09:52 AM in reply to: ltombrowski
    What do you want to do?  What is your career goal?
    Member
    ltombrowski
    01-30-2012 07:13 PM in reply to: ltombrowski
    I want to go into video game design.
    Bob_Zurunkle
    01-31-2012 09:20 AM in reply to: ltombrowski
    Browse the various products on this website and read into what each one does, mebbe?
    If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
