AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
When trying to get ribbon to load, error..... ........
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I work at a place where we use autocad, everywhere... And I'm in IT and i've been struggling with this for a day now. I got 2009/2011 to work, but when i try to get 2010 to work, it just doesnt want to cooperate. Now when i used to start it up a proxy graphics thing would pop up, and i figured out how to turn that off, but then no ribbon loads.
So i go to the command line and type in ribbon, and i get an error:
"Unhandled exception has occurred in a component, in your application. if you continue, the app will ignore this error and attempt to continue.
Object reference not set to an instance of an object"
and here are the details
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Autodesk.AutoCAD.Ribbon.RibbonPaletteSet.LoadRibbo
at Autodesk.AutoCAD.Ribbon.RibbonPaletteSet.Initializ
at Autodesk.AutoCAD.Ribbon.RibbonServices.CreateRibbo
at Autodesk.AutoCAD.Ribbon.Commands.Ribbon()
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker
at Autodesk.AutoCAD.Runtime.CommandClass.Invoke(Metho
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5448 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50
acdbmgd
Assembly Version: 18.0.0.0
Win32 Version: 18.0.309.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/AutoCAD%20Civil
msvcm90
Assembly Version: 9.0.30729.6161
Win32 Version: 9.00.30729.6161
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc90.crt_1
System
Win32 Version: 2.0.50727.5453 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.
System.Xml
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawin
PresentationFramework
Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.5011 built by: Win7SP1
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationF
WindowsBase
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3
PresentationCore
CodeBase: file:///C:/Windows/assembly/GAC_32/PresentationCor
AdWindowsInterop
Assembly Version: 0.0.0.0
AdWindows
Assembly Version: 2.1.0.0
Win32 Version: 2.1.123.309
acmgd
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Config
AcWindows
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.5420 built by: Win7SP1
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3
AcWindows.resources
Win32 Version: 18.0.55.0.0
AcCui
AeccUiWindows
Assembly Version: 7.0.3025.0
Win32 Version: 7.0.3025.0
AeccUiWindows.resources
Assembly Version: 7.0.1289.0
Win32 Version: 7.0.1289.0
PresentationFramework.Aero
Win32 Version: 3.0.6920.4902 built by: NetFXw7
AcLayer
System.Windows.Forms
Win32 Version: 2.0.50727.5446 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Window
AcLayer.resources
System.Web.Services
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Se
ManagedMC3
Assembly Version: 2.20.0.0
Win32 Version: 3.14.1
WindowsFormsIntegration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsFormsI
wpgjhhpx
AcCommandToolTips
AcCommandToolTips.resources
VerticalTips
Assembly Version: 13.0.141.0
Win32 Version: 13.0.141.0
AeccUiTooltipContent
AeccUiTooltipContent.resources
UIAutomationProvider
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/UIAutomationP
Accessibility
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
if anyone could help, that'd be awesome
Re: When trying to get ribbon to load, error..... ........
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Autodesk recommended uninstall/reinstall procedures are as follows
Uninstall: http://usa.autodesk.com/getdoc/id=TS45252
Reinstall (for XP/Vista users): http://usa.autodesk.com/getdoc/id=TS75218
Ensure the user installing/uninstalling and using the product have enough rights to do so (install and reinstall as local administrator):
Unable to run AutoCAD® as a restricted user http://usa.autodesk.com/getdoc/id=TS1055299
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I had the batch plot on the ribbon bar and have been using it for the last day or so. After reading several blogs about it, I realized that the ribbon was the problem, so I got rid of the batch plot on my ribbon.
When I tried to open the file again, it gave me a fatal error. ACAD then took a dump. I recovered the file, and everything seems to be ok now.
I don't know if that helps you, but it resolved my problem.
Good Luck!
