• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    JamaL9722060
    What sort of constraints that may achieve this behavior?
    131 Views, 6 Replies
    03-06-2012 01:40 PM
    In the screenshot below, I need to have symmetric behavior. For example, in case I stretch the indicated part of the drawing then I need the other corresponding part is to be stretched accordingly.
    What constraints settings might achieve this?
    The drawing is attached
    Thank you for the help,
    Best
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    Distinguished Contributor
    Re: What sort of constraints that may achieve this behavior?
    03-06-2012 02:26 PM in reply to: JamaL9722060
    use the equal (=) constraint
    you need to use the constraint dimenstions.... not regular dimensions
    see attached...
    JamaL9722060
    03-06-2012 03:59 PM in reply to: zzz144
    thank you for the help zzz144.
    the issue now is: if i change the dimension to be 2.5, then regular diemension doesn't change accordingly!
    best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
    03-06-2012 04:10 PM in reply to: JamaL9722060
    ah yes... you will have to redimension... because the true dimnesions lost their associativity...
    just be careful how you dimension...
    see attached.
    JamaL9722060
    03-06-2012 04:20 PM in reply to: zzz144
    then in this simple case, much more manual work is still needed!
    why ther is no way to let the regular dimesnion responds automatically?
    there should be a way. otherwise, the parametric is not useful.
    what do you think?
    Firefox 20.0,
    Kaspersky 2013.
    03-06-2012 04:35 PM in reply to: JamaL9722060
    well you are sort of correct. autocad is not meant to be parametric. this constraint and parametric dimesnions are simply a little experiment/addon they built in just recently... and it has its bugs...
    manual dimensions will obey the drawn geometry for as long as they can....
    whereas the parametric dimensions when they cannot obey the geometry they simply cease to exist.
    JamaL9722060
    03-07-2012 03:27 PM in reply to: zzz144
    Thansk ZZZ144. i'll try to post this issue in a separate thread.
    best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
