• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Distinguished Contributor
    Re: What is the most efficient way to draw a line inclined by
    04-19-2012 07:10 AM in reply to: JamaL9722060
    I like it! This is the sort of thing that I expected to find as an improvement. I normally run with Polar Tracking turned off so I didn't see the benefit until now. Thanx.
    This is a better solution for you Jamal, type DSETTINGS, click the lower of both of the two radio buttons on the right of the Polar Tracking tab and supply an increment angle that works for you.
    Please use plain text.
    JamaL9722060
    04-19-2012 01:17 PM in reply to: dbanaszak
    Thank you guys for the help. This is really a great tool.
    Do you have any idea how to let the tip reads the angle “clockwise”. For example, in the screenshots below, I need the tips to read 30 but not 330. Is that possible?
    Best
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    *Expert Elite*
    rkmcswain
    04-19-2012 01:30 PM in reply to: JamaL9722060
    JamaL9722060 wrote:
    What is the most efficient way to draw a line inclined by particular angle from another line?
    Polar tracking, relative to last segment? No construction lines needed.
    *Expert Elite*
    rkmcswain
    04-19-2012 01:35 PM in reply to: JamaL9722060
    Set ANGDIR to 1
    This should be the result
    JamaL9722060
    04-19-2012 01:44 PM in reply to: rkmcswain
    many thanks rkmcswain. now it works fine.
    best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
    JamaL9722060
    04-20-2012 01:29 AM in reply to: rkmcswain
    I’m again struggling with another issue!
    I wanted to sketch up the polygon (existing) shown in the screenshot below, but couldn’t figure out the best way to approach it. This time:
    1. The given angle is the interior,
    2. The angle is given in deg/min/sec
    How can I draw such given polygon efficiently?
    Many thanks
    Best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
    *Expert Elite*
    04-20-2012 01:37 AM in reply to: JamaL9722060
    do first a sketch of the figure and then place the contraints for distance and angle.
    What I have not tried now is if you can input the angle-value like you show the angular dimension with ° ' "
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    JamaL9722060
    04-20-2012 02:02 AM in reply to: alfred.neswadba
    Brilliant Alfred. This is a quite satisfactory solution.
    As you have already indiacted, what is missing is to represent the angle in deg/min/sec
    Many thanks
    Best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
    JamaL9722060
    04-23-2012 04:08 PM in reply to: alfred.neswadba
    Hi Alfred,
    A colleague indicated that changing the drawing units will solve this issue.
    Please, have a look on the screenshot below
    Best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
