• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    jessetherrien
    Vports: Modelspace Disappearing
    406 Views, 6 Replies
    06-28-2011 10:15 AM
    I'm having a little problem with the modelspace in a vport disappearing on me.
    I am trying to do some B.O.M. work, and sometimes I can't snap to a particular point/object, so I turn osnap off and zoom in to identify the correct object. After a certain point in the zoom the drawing regens and then the modelspace disappears completely.
    I tried a regenall, closing the drawing and starting it up again, but it's still not there. I checked the properties and it still says it's a vport. When I double click it to enter modelspace from the vport it doesn't take me into modelspace.
    I've checked my maxactvp, that's maxed out at 64. I've run an audit and that didn't work.
    Wondering if anyone else has encountered this problem and if you have a solution.
    Jesse T.
    Edited by
    Discussion_Admin
    Jesse T.
    AutoCAD Civil 3D 2011 32-bit
    Win XP Pro SP3
    Dual Core, 4 GB of RAM
    NVIDIA Quadro FX3700
    Please use plain text.
    SugarCAD
    Re: RE: Vports: Modelspace Disappearing
    06-28-2011 10:39 AM in reply to: jessetherrien
    What is your graphics card and driver?
    Active Member
    jessetherrien
    06-28-2011 11:13 AM in reply to: SugarCAD
    NVIDIA Quadro FX3700 and the driver version is 6.14.12.7061
    Jesse T.
    Win XP Pro SP3
    SugarCAD
    06-28-2011 11:38 AM in reply to: jessetherrien
    Latest Driver Try another driver, you can always rollback.
    Is it just this one drawing? I had similar problems when on XP, but mine would be resolved by closing the drawing and reopening, though only temporarily. This particular problem went away after new computer, card and Win 7.
    Active Member
    jessetherrien
    06-28-2011 12:08 PM in reply to: SugarCAD
    I've updated my driver and we'll see if that works.
    Sadly it's happening when I do that with most drawings.
    Jesse T.
    Win XP Pro SP3
    Active Member
    jessetherrien
    06-28-2011 12:40 PM in reply to: SugarCAD
    I also just noticed there is an option in the properties box in the misc section. It's an 'on' or 'off' toggle... and my vports were set to off :s
    I switched it to on and the vport is back to normal...
    Jesse T.
    Win XP Pro SP3
    Active Member
    Re: Vports: Modelspace Disappearing
    03-06-2012 11:07 AM in reply to: jessetherrien
    question back to you for your clarification: not sure if we have the same problem that you indicate your remedied. When in paperspace, when zooming, my viewport content disappears depending on position of zoom. Sometimes regen helps, mostly not. You indicate go to <properties> box, <misc> and turn ,<on>. Question, which properties box from what command?
    thanks.
    Jim K.
