• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    silvia918
    Viewport Color in Layer Property
    1002 Views, 3 Replies
    11-10-2011 03:19 PM
    All,
    I'm using AutoCAD 2011.  For some reason, in most of my dwg files,  when I changed the viewport color,  viewport layer color doesn't display correctly. Even though I start from the new file, it's the same way. But one day, I was working on some file other people send to me, it shows up correctly. Does anyone know how to fix it? It bothers me for a long time and I have been searching online but still can't find the answer.
    Highly appricate.
    Silvia
    Below is the screen shot.
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: Viewport Color in Layer Property
    11-10-2011 04:08 PM in reply to: silvia918
    Do you see where it said By Layer (VP)      It's Color Override.
    Go to Layer Properties Manager, on Layer 0,  look for 2 different colors, make them the same.
    (It's good not to make viewport on layer zero)
    *Expert Elite*
    11-11-2011 09:20 AM in reply to: Patchy
    If you, like me, hate viewport layer overrides (such as this), set the system variable VPLAYEROVERRIDESMODE to 0 (zero).
    You may also have to go into your layer manager, right-click on a layer and choose the option:
    Remove Viewport Overrides for > All Layers > In All Viewports.
    They are occasionally useful, but they shouldn't behave this way by default.
    (Also, it's not good to have anything on layer zero, IMO)
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    New Member
    silvia918
    11-14-2011 08:27 AM in reply to: troma
    Probably I didn't explain my question well.  I was hoping to show the viewport override, but for some reason it couldn't display correctly. However, troma gave me the hint of what my problem is. If I set VPLAYEROVERRIDESMODE to 1, my problem is solved.
    Thanks for all your responses.
    Silvia
