• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    Using Windows Explorer to Search for text in DWG files
    1842 Views, 11 Replies
    05-16-2011 12:30 PM
    Hello;
    We are running Autocad 2012 (64 bit) on Windows 7. Does anyone know how to get Windows Explorer to search for text inside of DWG files?
    Sincerely;
    Michelle
    Please use plain text.
    3wood
    Re: Using Windows Explorer to Search for text in DWG files
    05-17-2011 05:26 AM in reply to: michellemcpeek6324
    As far as I know, Window can perform content search in some old version of dwg files such AutoCAD 2004.
    You can save a dwg file in different versions and test.
    3wood
    CAD KITS
    New Member
    05-17-2011 05:18 PM in reply to: 3wood
    Thankyou for the suggestion - tried several different DWG versions and found no joy....looking for more ideas.
    Sincerely;
    Michelle
    Employee
    Craig.Godfrey
    05-17-2011 06:01 PM in reply to: michellemcpeek6324
    Michelle,
    Have you tried using Content Explorer which is new in 2012? It allows you to search for various objects within a dwg file such as text, blocks, attributes, layers, dimensions, etc. You can find it in the Plug-Ins tab or by typing contentexplorer in the command line. Once you configure Content Explorer to watch a folder that contains your design files it will index them and you can then search for your information.
    There are a few videos on Exchange that show what you can do with Content Explorer.
    Craig S. Godfrey
    Software QA Engineer
    Active Member
    04-08-2012 12:19 PM in reply to: Craig.Godfrey
    Thank you Craig. Found the text I wanted in my drawing files. Lot easier than doing it from Win 7 Explorer!!!
    Active Contributor
    10-15-2012 09:35 AM in reply to: Craig.Godfrey
    Contentexplorer is good but it's very limited in functionality.  I tried to use it but it does not allow network folders.  To me this is very odd, most companies put their drawings on network folders.
    Is there any other way of searching for text inside of a drawing?
    Don
    10-15-2012 09:38 AM in reply to: donjacobsen
    As long as the server has a Windows operating system you can install the Content-Explorer service on every server and connect to this service then from your workstation.
    - alfred -
    Alfred NESWADBA
    Active Contributor
    10-15-2012 09:50 AM in reply to: alfred.neswadba
    Thanks for the info Alfred.  I guess I need to get with my IT Dept to get this done.
    Wish me luck - lol.
    Don
    10-15-2012 10:05 AM in reply to: donjacobsen
    >> Wish me luck
    I do :smileywink:
    - alfred -
    Alfred NESWADBA
    Valued Mentor
    TerryDotson
    10-15-2012 11:55 AM in reply to: donjacobsen
    Take a look at the DwgSearch tool in DotSoft's ToolPac, it will let you search DWG files without needing to build external indexes or anything running on a server, etc.
