• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Contributor
    Use fields in a table to pull dimension text for cut lists
    1040 Views, 4 Replies
    06-18-2010 03:40 PM
    I am new to fields but I would like to know if there a way to use fields in a table to pull the measurements out of dimensions snapped in a drawing (or layout) and place them in that table.
    I create framing drawings and am looking for a quick way to put together a cut list without having to manually type dimensions into a table.
    Thoughts?
    Thanks for any tips.
    Matt Waldenmeyer
    Manager of Shop Operations
    3DX Scenic Studio
    Cincinnati Ohio
    513.469.1015
    www.3dxscenic.com
    Please use plain text.
    Valued Contributor
    Re: Use fields in a table to pull dimension text for cut lists
    06-19-2010 05:09 AM in reply to: mwaldenmeyer
    Yes, it is quite possible :smileysurprised:) Double click table cell, then right click and choose Insert Field... When In Field dialog: Field names: choose Object Object type: click on button Select object and then click on appropriate dimension in drawing Back in Field dialog: Property: choose Measurement Format: Current units (or some other) There is button for Additional formating, if needed Press OK and - voila - you've got dimensions in table If objects in drawing change some dimensions, after drawing regeneration fields are updated.
    Active Contributor
    06-19-2010 05:31 AM in reply to: mwaldenmeyer
    Thanks!
    That worked very well.
    Now to one up it, is there a way to make it an easily repeatable command or command string? Would this have to be a LISP expression? This functionality is already very cool, I would like to automate it a little, if possible.
    Thanks again for your help!
    Matt Waldenmeyer
    3DX Scenic Studio
    Cincinnati Ohio
    513.469.1015
    www.3dxscenic.com
    New Member
    04-19-2012 06:05 PM in reply to: mwaldenmeyer
    This is great!
    Another follow up... can you do the opposite? i.e. Create a table and have multiple labels throughout your sheet source a cell in that table?
    New Member
    04-20-2012 09:15 AM in reply to: hughes.huck
    I've been able to grab numerical data from tables and insert them as fields... but not text.
    Any help would be greatly appreciated!
