AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Unchanged drawing is "changed" by zooming/pa nning
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I guess because the view is actually saved, but is there a way to disable view saving or any other way that an UNCHANGED drawing does not ask me to save?
This is related to the option to combine zoom and pan actions in undo, but what I really want is to remove them from undo completely. That way if you zoom out you could see what changes, and you wouldn't LOSE THE ABILITY TO REDO by zooming.
Optimally, AUTOCAD could ask for each drawing whether it should save, and then save the ones that you selected, together. This way you could just leave the application to save and tab to something else
I'd be really happy to see this option in future releases. Because when you undo you can't always see the change, and being able to zoom/pan independently of the action history would mean that you can look at the drawing without losing the latest drawing.
Kent
Re: Unchanged drawing is "changed" by zooming/pa nning
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You mean work like every other CAD programme I have ever used?!!!
Hmmm, that's not the AutoCAD way, they'll do it how they please, and take no notice of the end user!!
It would be fantasic if this was changed and zoom was removed from the undo command, and not recognized as a command so save or not didn't come up, but I for one aint holding my breath. ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I hope they don't. We have had much more issue with guys zoomed into an area attempting to undo something and literally undoing half a drawing before they realized because it was off screen.
If you change something like say your viewpoint, then the file is changed. if you wish to save that change or discard that change the system needs to know. If you're working on a map the size of Harris County Texas, you'd really like it to still be where you left it yesterday.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Your first point has nothing to do with the zoom and or undo command; you can't blame the software if the user doesn't know what they are doing!
Your second point doesn't really make much sence regarding zoom either. Taking zoom out so that AutoCAD doesn't see it as a change wouldn't change where you last made a save. If you wanted to save the view you last worked on, then just hit save, and then the next time you opened that file, your last view save would still be there.
The point we're trying to make is if you want to open a drawing just to look at, to check it or just use as a reference, and all you are doing is zooming and panning and have made no changes, we do not want to be asked if we want to save it. So, we would like AutoCAD to recongnize this and ignore the zooming and panning, and see that no changes have been made to that file, and therefore think nothing has happened, so no more "Do you want to save?"
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i was going to say that Autodesk's answer would be "open the file as read only".....but even if you do that you still get asked if you want to save the file, which seems a little crazy when you can not actually save a read only file...:-) you certainly have to give the clowns @ autodesk 10 out of 10 for entertainment value...:-)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Your $3000+ software has a cool ability called end-user customization: create a right-click selection or F-key or Mouse-key or toolbar button or ribbon panel selection or Qat button item that just closes the file and answers no, and take ownership of your desires and wishes.
Need help doing just that? ask here, or search/repost here:
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP
Waiting for a 'factory' change when a user edit is right in front of you is such a waste of time.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That *would* be a pretty good answer if opening files as read-only was easier. Its way too easy for somebody working on a drawing and needing to look at another to just open it with write-access in the current session. Who wants to launch another application (TrueView, Design Review, Simulate) when they already have an application open?
A per-session/registry system variable that toggles the default open behaviour between read-write and read-only might not be a bad idea. Something else that might be a good idea would be a tool/function/whatever inside AutoCAD to open drawings with an appropriate viewer application, making the process more transparent to the user.
Adopt. Adapt. Overcome. Or be overcome.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
it's a mess and the ability to close without saving really doesn't help, because you can just close-'n' if that's all you want.
You just don't know if you did actually make some small change that you don't remember, so I rarely close without saving. But save can seem to take ages sometimes, especially at the beginning or end of the day when everyone is using the network.
Also, it currently only zooms to the area after it undoes, so you are often left wondering what was undone anyway. If you could zoom out iwould help you see where the change happens.
Oh and yes, it should be an option, for those of you who like it how it is, Didn't I say that?
