AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Trim + Shift
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Inside the trim command I cannot hit "shift" to switch to the extend command instead.
any suggestions?
Re: Trim + Shift
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You must hold the Shift key down while picking on the object.
Re: Trim + Shift
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes I have done that but nothing happens.
Re: Trim + Shift
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It may be a system variable issue.
i can't seem to select anything if holding down the shift key in other commands as well.
(similar post - cant toggle ortho mode with the shift key anymore - ortho comes on but i can't pick a point)
Re: Trim + Shift
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Command: TRIM
Current settings: Projection=View, Edge=Extend
Select cutting edges ...
Select objects or <select all>: Specify opposite corner: 2 found
Select objects:
Select object to trim or shift-select to extend or
[Fence/Crossing/Project/Edge/eRase/Undo]:
After starting the TRIM command and selecting the cutting edges, does it remind you that you can use shift, as shown above in red?
Re: Trim + Shift
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes
Re: Trim + Shift
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
my projection is set to UCS.
