• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Contributor zph
    Trapped within viewport window
    1054 Views, 3 Replies
    02-22-2010 11:07 AM
    While working in the layout view I double-clicked the viewport window. The screen then was blank with a dashed red line as a border.
    I don't recall what I did to get out of this, but I probably hit escape a few times. Now the original drawing is shown and the viewport window is highlited (bolded). I can no longer select the drawing, but can zoom within the viewport window. I can flip between the other layout views (which are unaffected). I'd like to get out of whatever command or setting I double-clicked in to.
    Help, please.
    Please use plain text.
    *Matt Kolberg
    Re: Trapped within viewport window
    02-22-2010 11:23 AM in reply to: zph
    VPMAX and VPMIN are the commands for this. There is also a button on the
    status bar.
    Matt Kolberg
    Global CADD Systems - A division of Cansel
    "zph" wrote in message news:6341733@discussion.autodesk.com...
    > Help, please.
    *Pro
    02-22-2010 11:29 AM in reply to: zph
    You can also double-click on the red border to bring you back to the Layout
    Contributor zph
    02-22-2010 11:45 AM in reply to: zph
    VPMIN worked - Thanks for the quick response.
