• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    This may simple but...
    232 Views, 10 Replies
    11-30-2011 05:58 AM
    I have a blocks that have multiple nodes on the same x,y axis but different Z points (elevations)
    When I copy in the plan view, node to node, it picks what ever z node point it feels like.. Is there some simple thing I am missing that will allow me to keep - or force - my pick and copy point to a certain elevation?
    Please use plain text.
    Patchy
    Re: This may simple but...
    11-30-2011 06:26 AM in reply to: XlhHarley
    Simple, because you have many Z nodes, use isometric view.
    Use the right tools for the right job.
    Product Support
    12-02-2011 08:15 AM in reply to: XlhHarley
    Maybe you could use point filters?
    Not sure without seeing your drawing.
    Cheers,
    Luciane
    Luciane Conceição
    Product Support Specialist
    Valued Contributor
    12-02-2011 08:32 AM in reply to: XlhHarley
    Drawing attached for your look
    Product Support
    12-02-2011 08:58 AM in reply to: XlhHarley
    I think it works:
    Copy > select object > enter > type .z of 0 (for 0 elevation) > snap to the node when asked for XY and you have the first point in the XY position of the node, elevation 0.
    Is this what you are looking for?
    Cheers,
    Luciane
    ___
    Please click the button "Accept as Solution" if this suggestion resolves your issue.
    Valued Contributor
    12-02-2011 09:08 AM in reply to: XlhHarley
    Thanks for the reply
    when i do this - it still walks
    From the dwg - its much easier to work in plan view. This is a simple dwg. When I copy a group and go from one vertical pole to another. I am looking for the z elevation not to change. Right now , every time I copy from node to node, It snaps to the upper node on the vertical poles
    Product Support
    12-06-2011 09:20 AM in reply to: XlhHarley
    It seems to work well for me, check the video:
    http://screencast.com/t/0xyGTi12bio
    Cheers,
    Luciane
    GrantsPirate
    12-06-2011 10:22 AM in reply to: XlhHarley
    First in Options, Drafting, check off "Replace Z value with current elevation",
    Then in the drawing set the ELEVATION to the elevation you want to work in.
    But it really is best to work in an iso view on a 3D model.
    JGerth
    12-06-2011 10:44 AM in reply to: XlhHarley
    look into OSAPZ setvar, and using point filters, (.xy  .z)
    Valued Contributor
    12-08-2011 06:49 AM in reply to: JGerth
    Thanks  this works great
