AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Text Mask Shrink Wrap?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have always struggled with AutoCAD's text masking. I love the masking ability which makes drawings that are clean looking and easier to read. My issue is with the way the mask border is created. The mask creates a rectangular border that does not "shrink wrap" around the text. This can lead to masking more text than originally intended.
I am looking for a quick and easy way to wrap the mask around text. Right now the only way to accomplish the desired result is to explode the text into single lines and then mask each individual line. This creates issues with leaders and is a more time consuming process.
Any thoughts or comments would be appreciated!
Re: Text Mask Shrink Wrap?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The problem is that you're using Mtext. You won't have that problem with Dtext. See the attached - Mtext at the top and Dtext at the bottom.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
wengle - thanks for the response.
"DTEXT" seems to create individual lines of TEXT. I still have to convert them to MTEXT to utilize masking and they cannot be grouped and attached to leaders (which is my ultimate goal). I was hoping for a solution that uses MTEXT, which can be attached to leaders.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You can use masking for Dtext and you can also attach a leader to Dtext. Try it.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The size of the text mask is the same as the size of the text box. Make the text box smaller and the mask will be made smaller as well. If you double click on the arrow at the end of the WYSIWYG MTEXT editor, the text box will automagically shrink to fit the text.
If this is still to big you can change the size of the 'Padding' in the back ground Mask Dialogue
@CadSetterOut
Please use the
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I just realized my Faux-pa... ![]()
@CadSetterOut
Please use the
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I whipped up a quick post. Take a look:
How to ‘Shrink Wrap’ AutoCAD Masked Text
@CadSetterOut
Please use the
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Paul. Saw what you wrote, It doesn't seem to 'shrink wrap' only make a smaller text box around the whole mtext entity. Any way to just mask the text within the frame and not the text frame itself?
I guess I want a little more intelligance from the masking feature.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm not sure I follow what you mean. Would you like the masking boundary to follow the curves of the text?
How about whipping up a image to show us what you are after?
@CadSetterOut
Please use the
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Click on the attachement on the original posting for an image.
