• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    New Member
    colorado.erickson
    Text Mask Shrink Wrap?
    2084 Views, 11 Replies
    07-27-2010 09:58 AM
    I have always struggled with AutoCAD's text masking. I love the masking ability which makes drawings that are clean looking and easier to read. My issue is with the way the mask border is created. The mask creates a rectangular border that does not "shrink wrap" around the text. This can lead to masking more text than originally intended.
    I am looking for a quick and easy way to wrap the mask around text. Right now the only way to accomplish the desired result is to explode the text into single lines and then mask each individual line. This creates issues with leaders and is a more time consuming process.
    Any thoughts or comments would be appreciated!
    Please use plain text.
    Valued Mentor
    Re: Text Mask Shrink Wrap?
    07-27-2010 10:59 AM in reply to: colorado.erickson
    The problem is that you're using Mtext. You won't have that problem with Dtext. See the attached - Mtext at the top and Dtext at the bottom.
    New Member
    colorado.erickson
    07-27-2010 11:30 AM in reply to: colorado.erickson
    wengle - thanks for the response.
    "DTEXT" seems to create individual lines of TEXT. I still have to convert them to MTEXT to utilize masking and they cannot be grouped and attached to leaders (which is my ultimate goal). I was hoping for a solution that uses MTEXT, which can be attached to leaders.
    Valued Mentor
    07-27-2010 01:00 PM in reply to: colorado.erickson
    You can use masking for Dtext and you can also attach a leader to Dtext. Try it.
    PaulMunford
    07-27-2010 01:47 PM in reply to: colorado.erickson
    The size of the text mask is the same as the size of the text box. Make the text box smaller and the mask will be made smaller as well. If you double click on the arrow  at the end of the WYSIWYG MTEXT editor, the text box will automagically shrink to fit the text.
    If this is still to big you can change the size of the 'Padding' in the back ground Mask Dialogue
    63iE1043824C04755E9
    59iB1484C67ADBAC0A6.
    61iCBD773F7A830FA34
    The CAD Setter Out Blog
    @CadSetterOut
    Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
    PaulMunford
    07-27-2010 01:58 PM in reply to: PaulMunford
    I just realized my Faux-pa... :smileywink:
    @CadSetterOut
    PaulMunford
    04-09-2011 01:59 PM in reply to: PaulMunford
    I whipped up a quick post. Take a look:
    How to ‘Shrink Wrap’ AutoCAD Masked Text
    @CadSetterOut
    04-21-2011 10:33 AM in reply to: colorado.erickson
    Paul.  Saw what you wrote, It doesn't seem to 'shrink wrap' only make a smaller text box around the whole mtext entity.  Any way to just mask the text within the frame and not the text frame itself?
    I guess I want a little more intelligance from the masking feature.
    PaulMunford
    05-03-2011 04:55 AM in reply to: matto235
    I'm not sure I follow what you mean. Would you like the masking boundary to follow the curves of the text?
    How about whipping up a image to show us what you are after?
    @CadSetterOut
    New Member
    jesse.erickson
    05-03-2011 09:35 AM in reply to: PaulMunford
    Click on the attachement on the original posting for an image.
