• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Member
    Re: Text Lisp routine needed for merging text styles..
    03-16-2010 04:00 PM in reply to: caddoodler
    Yes after I dropped the .lsp file into my acad drawing, I tried to run it and it keeps giving me that "; error: no function definition: EXTANG" error prompt. Please bare with me and explain to me how to fix this error and get the .lsp routine to work. I am a BEGINNER at .lsp files..as a matter of fact this will be my 1st time ever installing and running one. Thank you in advance for your time in answering my questions.
    Please use plain text.
    Active Member
    03-16-2010 05:26 PM in reply to: caddoodler
    Sorry for my questions that seem 'Capt Obvious' to you but I am new to this...Where do I find the acad.lsp file and do I just add to the end or replace their txt's with your:
    (Defun Extang (A)
    (Setq A (Tblsearch "STYLE" A))
    (Setq J (Cdr (Assoc 50 A)))
    Then it is my understanding that In acad at the command line I type: CHGSTY.
    Thanks!
    *None
    03-16-2010 06:26 PM in reply to: caddoodler
    > (Defun Extang (A)
    > Thanks!
    Below is your acad2010doc.lsp file with the definition added. Just
    replace your existing acad2010doc.lsp with the one below. The
    acad2010doc.lsp file you have is in your Support folder. In order to use
    the chgsty.lsp file, you MUST load it, i.e., type at the Command line
    *(load "chgsty")* - exactly as shown (but without the *.) Once loaded,
    you can then type CHGSTY and the program will work.
    ; Next available MSG number is 104
    ; MODULE_ID ACAD2010doc_LSP_
    ;;; ACAD2010DOC.LSP Version 1.0 for AutoCAD 2010
    ;;; Copyright (C) 1994 - 2009 by Autodesk, Inc.
    ;;; Permission to use, copy, modify, and distribute this software
    ;;; for any purpose and without fee is hereby granted, provided
    ;;; that the above copyright notice appears in all copies and
    ;;; that both that copyright notice and the limited warranty and
    ;;; restricted rights notice below appear in all supporting
    ;;; documentation.
    ;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
    ;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
    ;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC.
    ;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
    ;;; UNINTERRUPTED OR ERROR FREE.
    ;;; Use, duplication, or disclosure by the U.S. Government is subject to
    ;;; restrictions set forth in FAR 52.227-19 (Commercial Computer
    ;;; Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
    ;;; (Rights in Technical Data and Computer Software), as applicable.
    ;;; Note:
    ;;; This file is loaded automatically by AutoCAD every time
    ;;; a drawing is opened. It establishes an autoloader and
    ;;; other utility functions.
    ;;; Globalization Note:
    ;;; We do not support autoloading applications by the native
    ;;; language command call (e.g. with the leading underscore
    ;;; mechanism.)
    ;;;===== Raster Image Support for Clipboard Paste Special =====
    ;; IMAGEFILE
    ;; Allow the IMAGE command to accept an image file name without
    ;; presenting the file dialog, even if filedia is on.
    ;; Example: (imagefile "c:/images/house.bmp")
    (defun imagefile (filename / filedia-save cmdecho-save)
    (setq filedia-save (getvar "FILEDIA"))
    (setq cmdecho-save (getvar "CMDECHO"))
    (setvar "FILEDIA" 0)
    (setvar "CMDECHO" 0)
    (command "_.-image" "_attach" filename)
    (setvar "FILEDIA" filedia-save)
    (setvar "CMDECHO" cmdecho-save)
    (princ)
    ;;;=== General Utility Functions ===
    ; R12 compatibility - In R12 (acad_helpdlg) was an externally-defined
    ; ADS function. Now it's a simple AutoLISP function that calls the
    ; built-in function (help). It's only purpose is R12 compatibility.
    ; If you are calling it for anything else, you should almost certainly
    ; be calling (help) instead.
    (defun acad_helpdlg (helpfile topic)
    (help helpfile topic)
    (defun *merr* (msg)
    (setq *error* m:err m:err nil)
    (princ)
    (defun *merrmsg* (msg)
    (princ msg)
    (princ)
    ;; Loads the indicated ARX app if it isn't already loaded
    ;; returns nil if no load was necessary, else returns the
    ;; app name if a load occurred.
    (defun verify_arxapp_loaded (app)
    (if (not (loadedp app (arx)))
    (arxload app f)
    ;; determines if a given application is loaded...
    ;; general purpose: can ostensibly be used for appsets (arx) or (ads) or....
    ;; app is the filename of the application to check (extension is required)
    ;; appset is a list of applications, (such as (arx) or (ads)
    ;; returns T or nil, depending on whether app is present in the appset
    ;; indicated. Case is ignored in comparison, so "foo.arx" matches "FOO.ARX"
    ;; Also, if appset contains members that contain paths, app will right-match
    ;; against these members, so "bar.arx" matches "c:\\path\\bar.arx"; note
    that
    ;; "bar.arx" will *not* match "c:\\path\\foobar.arx."
    (defun loadedp (app appset)
    (cond (appset (or
    ;; exactly equal? (ignoring case)
    (= (strcase (car appset))
    (strcase app))
    ;; right-matching? (ignoring case, but assuming that
    ;; it's a complete filename (with a backslash
    before it)
    (and
    (> (strlen (car appset)) (strlen app))
    (= (strcase (substr (car appset)
    (- (strlen (car appset))
    (strlen app)
    (strcase (strcat "\\" app))
    ;; no match for this entry in appset, try next one....
    (loadedp app (cdr appset)) )))
    Defun Extang (A)
    ;;; ===== Single-line MText editor =====
    (defun LispEd (contents / fname dcl state)
    (if (not (setq fname (getvar "program")))
    (setq fname "acad")
    (strcat fname ".dcl")
    (setq dcl (load_dialog fname))
    (if (not (new_dialog "LispEd" dcl)) (exit))
    (set_tile "contents" contents)
    (mode_tile "contents" 2)
    (action_tile "contents" "(setq contents $value)")
    (action_tile "accept" "(done_dialog 1)")
    (action_tile "mtexted" "(done_dialog 2)" )
    (setq state (start_dialog))
    (unload_dialog dcl)
    (cond
    ((= state 1) contents)
    ((= state 2) -1)
    (t 0)
    ;;; ===== Discontinued commands =====
    (defun c:ddselect(/ cmdecho-save)
    (command "._+options" 8)
    (princ)
    (defun c:ddgrips(/ cmdecho-save)
    (princ)
    (defun c:gifin ()
    (alert "\nThe GIFIN command is no longer supported.\nUse the IMAGE
    command to attach raster image files.\n")
    (princ)
    (defun c:smileytongue:cxin ()
    (alert "\nThe PCXIN command is no longer supported.\nUse the IMAGE
    (princ)
    (defun c:tiffin ()
    (alert "\nThe TIFFIN command is no longer supported.\nUse the IMAGE
    (princ)
    (defun c:ddemodes()
    (alert "The Object Properties toolbar incorporates DDEMODES
    functionality. \nDDEMODES has been discontinued. \n\nFor more
    information, select \"Object Properties toolbar\" from the AutoCAD Help
    Index tab.")
    (princ)
    (defun c:ddrmodes(/ cmdecho-save)
    (command "._+dsettings" 0)
    (princ)
    ;;; ===== AutoLoad =====
    ;;; Check list of loaded applications ("ads" or "arx")
    ;;; for the name of a certain appplication .
    ;;; Returns T if is loaded.
    (defun ai_AppLoaded (appname apptype)
    (apply 'or
    (mapcar
    '(lambda (j)
    (wcmatch
    (strcase j T)
    (strcase (strcat "*" appname "*") T)
    (eval (list (read apptype)))
    ;; Native Rx commands cannot be called with the "C:" syntax. They must
    ;; be called via (command). Therefore they require their own autoload
    ;; command.
    (defun autonativeload (app cmdliste / qapp)
    (setq qapp (strcat "\"" app "\""))
    (setq initstring "\nInitializing...")
    (mapcar
    '(lambda (cmd / nom_cmd native_cmd)
    (progn
    (setq nom_cmd (strcat "C:" cmd))
    (setq native_cmd (strcat "\"_" cmd "\""))
    (if (not (eval (read nom_cmd)))
    (eval
    (read (strcat
    "(defun " nom_cmd "()"
    "(setq m:err *error* *error* *merrmsg*)"
    "(if (ai_ffile " qapp ")"
    "(progn (princ initstring)"
    "(_autoarxload " qapp ") (command " native_cmd "))"
    "(ai_nofile " qapp "))"
    "(setq *error* m:err m:err nil))"
    cmdliste)
    nil
    (defun _autoqload (quoi app cmdliste / qapp symnam)
    (mapcar
    '(lambda (cmd / nom_cmd)
    (progn
    (eval
    (read (strcat
    "(defun " nom_cmd "( / rtn)"
    "(_auto" quoi "load " qapp ") (setq rtn (" nom_cmd
    "(setq *error* m:err m:err nil)"
    "rtn)"
    cmdliste)
    nil
    (defun autoload (app cmdliste)
    (_autoqload "" app cmdliste)
    (defun autoarxload (app cmdliste)
    (_autoqload "arx" app cmdliste)
    (defun autoarxacedload (app cmdliste / qapp symnam)
    (mapcar
    (progn
    (eval
    (read (strcat
    "(defun " nom_cmd "( / oldcmdecho)"
    "(_autoarxload " qapp ")"
    "(setq oldcmdecho (getvar \"CMDECHO\"))"
    "(setvar \"CMDECHO\" 0)"
    "(command " "\"_" cmd "\"" ")"
    "(setvar \"CMDECHO\" oldcmdecho))"
    "(princ))"
    cmdliste)
    nil
    (defun _autoload (app)
    ; (princ "Auto:smileysad:load ") (princ app) (princ ")") (terpri)
    (load app)
    (defun _autoarxload (app)
    ; (princ "Auto:smileysad:arxload ") (princ app) (princ ")") (terpri)
    (arxload app)
    (defun ai_ffile (app)
    (or (findfile (strcat app ".lsp"))
    (findfile (strcat app ".exp"))
    (findfile (strcat app ".exe"))
    (findfile (strcat app ".arx"))
    (findfile app)
    (defun ai_nofile (filename)
    (princ
    (strcat "\nThe file "
    filename
    "(.lsp/.exe/.arx) was not found in your search path folders."
    (princ "\nCheck the installation of the support files and try again.")
    (princ)
    ;;;===== AutoLoad LISP Applications =====
    ; Set help for those apps with a command line interface
    (setfunhelp "c:gotourl" "" "gotourl")
    (autoload "edge" '("edge"))
    (setfunhelp "C:edge" "" "edge")
    (autoload "3d" '("3d" "3d" "ai_box" "ai_pyramid" "ai_wedge" "ai_dome"
    "ai_mesh" "ai_sphere" "ai_cone" "ai_torus" "ai_dish")
    (setfunhelp "C:3d" "" "3d")
    (setfunhelp "C:ai_box" "" "3d_box")
    (setfunhelp "C:ai_pyramid" "" "3d_pyramid")
    (setfunhelp "C:ai__wedge" "" "3d_wedge")
    (setfunhelp "C:ai_dome" "" "3d_dome")
    (setfunhelp "C:ai_mesh" "" "3d_mesh")
    (setfunhelp "C:ai_sphere" "" "3d_sphere")
    (setfunhelp "C:ai_cone" "" "3d_cone")
    (setfunhelp "C:ai_torus" "" "3d_torus")
    (setfunhelp "C:ai_dish" "" "3d_dish")
    (autoload "3darray" '("3darray"))
    (setfunhelp "C:3darray" "" "3darray")
    (autoload "mvsetup" '("mvsetup"))
    (setfunhelp "C:mvsetup" "" "mvsetup")
    (autoload "attredef" '("attredef"))
    (setfunhelp "C:attredef" "" "attredef")
    (autoload "tutorial" '("tutdemo" "tutclear"
    "tutdemo"
    "tutclear"))
    ;;;===== AutoArxLoad Arx Applications =====
    ;;; ===== Double byte character handling functions =====
    (defun is_lead_byte(code)
    (setq asia_cd (getvar "dwgcodepage"))
    (cond
    ( (or (= asia_cd "dos932")
    (= asia_cd "ANSI_932")
    (or (and (<= 129 code) (<= code 159))
    (and (<= 224 code) (<= code 252))
    ( (or (= asia_cd "big5")
    (= asia_cd "ANSI_950")
    (and (<= 129 code) (<= code 254))
    ( (or (= asia_cd "gb2312")
    (= asia_cd "ANSI_936")
    (and (<= 161 code) (<= code 254))
    ( (or (= asia_cd "johab")
    (= asia_cd "ANSI_1361")
    (and (<= 132 code) (<= code 211))
    ( (or (= asia_cd "ksc5601")
    (= asia_cd "ANSI_949")
    ;;; FITSTR2LEN
    ;;; Truncates the given string to the given length.
    ;;; This function should be used to fit symbol table names, that
    ;;; may turn into \U+ sequences into a given size to be displayed
    ;;; inside a dialog box.
    ;;; Ex: the following string:
    ;;; "This is a long string that will not fit into a 32 character
    static text box."
    ;;; would display as a 32 character long string as follows:
    ;;; "This is a long...tatic text box."
    (defun fitstr2len (str1 maxlen)
    ;;; initialize internals
    (setq tmpstr str1)
    (setq len (strlen tmpstr))
    (if (> len maxlen)
    (progn
    (setq maxlen2 (/ maxlen 2))
    (if (> maxlen (* maxlen2 2))
    (setq maxlen2 (- maxlen2 1))
    (if (is_lead_byte (substr tmpstr (- maxlen2 2) 1))
    (setq tmpstr1 (substr tmpstr 1 (- maxlen2 3)))
    (setq tmpstr1 (substr tmpstr 1 (- maxlen2 2)))
    (if (is_lead_byte (substr tmpstr (- len (- maxlen2 1)) 1))
    (setq tmpstr2 (substr tmpstr (- len (- maxlen2 3))))
    (setq tmpstr2 (substr tmpstr (- len (- maxlen2 2))))
    (setq str2 (strcat tmpstr1 "..." tmpstr2))
    ) ;;; progn
    (setq str2 (strcat tmpstr))
    ) ;;; if
    ) ;;; defun
    ;;; If the first object in a selection set has an attached URL
    ;;; Then launch browser and point to the URL.
    ;;; Called by the Grips Cursor Menu
    (defun C:gotourl ( / ssurl url i)
    (setq m:err *error* *error* *merrmsg* i 0)
    ; if some objects are not already pickfirst selected,
    ; then allow objects to be selected
    (if (not (setq ssurl (ssget "_I")))
    (setq ssurl (ssget))
    ; if geturl LISP command not found then load arx application
    (if (/= (type geturl) 'EXRXSUBR)
    (arxload "acapp")
    ; Search list for first object with an URL
    (while (and (= url nil) (< i (sslength ssurl)))
    (setq url (geturl (ssname ssurl i))
    i (1+ i))
    ; If an URL has be found, open browser and point to URL
    (if (= url nil)
    (alert "No Universal Resource Locator associated with the object.")
    (command "_.browser" url)
    (princ)
    ;; Used by the import dialog to silently load a 3ds file
    (defun import3ds (filename / filedia_old render)
    ;; Load Render if not loaded
    (setq render (findfile "acRender.arx"))
    (if render
    (verify_arxapp_loaded render)
    (quit)
    ;; Save current filedia & cmdecho setting.
    ;; Call 3DSIN and pass in filename.
    (c:3dsin 1 filename)
    ;; Reset filedia & cmdecho
    (princ)
    ; New "Select All" function. Cannot be called transparently.
    (defun c:ai_selall ( / ss old_error a b old_cmd old_hlt)
    (setq a "CMDECHO" b "HIGHLIGHT"
    old_cmd (getvar a) old_hlt (getvar b)
    old_error *error* *error* ai_error)
    (if (ai_notrans)
    (progn
    (princ "Selecting objects...")
    (setvar a 0)
    (setvar b 0)
    (command "_.SELECT" "_ALL" "") ; Create Previous SS
    (setvar a old_cmd)
    (setvar b old_hlt)
    (setq ss (ssget "_P"))
    (sssetfirst ss ss) ; Non-gripped, but selected (someday!)
    (princ "done.\n")
    (setq *error* old_error old_error nil ss nil)
    (princ)
    ;;; Routines that check CMDACTIVE and post an alert if the calling routine
    ;;; should not be called in the current CMDACTIVE state. The calling
    ;;; routine calls (ai_trans) if it can be called transparently or
    ;;; (ai_notrans) if it cannot.
    ;;; 1 - Ordinary command active.
    ;;; 2 - Ordinary and transparent command active.
    ;;; 4 - Script file active.
    ;;; 8 - Dialogue box active.
    (defun ai_trans ()
    (if (zerop (logand (getvar "cmdactive") (+ 2 8) ))
    T
    (progn
    (alert "This command may not be invoked transparently.")
    nil
    (defun ai_transd ()
    (if (zerop (logand (getvar "cmdactive") (+ 2) ))
    T
    (progn
    nil
    (defun ai_notrans ()
    (if (zerop (logand (getvar "cmdactive") (+ 1 2 8) ))
    T
    (progn
    nil
    ; New function for invoking the product support help through the browser
    (defun C:ai_product_support ()
    (setq url "http://www.autodesk.com/autocad-support")
    (defun C:ai_product_support_safe ()
    (setq 404page "WSProdSupp404.htm")
    (command "_.browser2" 404page url)
    (defun C:ai_training_safe ()
    (setq url "http://www.autodesk.com/autocad-training")
    (setq 404page "WSTraining404.htm")
    (defun C:ai_custom_safe ()
    (setq url "http://www.autodesk.com/developautocad")
    (setq 404page "WSCustom404.htm")
    ;;; ==== Originally defined in Acad.mnl ====
    ;;; These were moved to this file to ease migration.
    (princ "\nAutoCAD menu utilities ")
    ;;;=== Icon Menu Functions ===
    ;;; View -> Layout -> Tiled Viewports...
    (defun ai_tiledvp_chk (new)
    (if (= (getvar "TILEMODE") 0)
    (progn
    (princ "\n** Command not allowed in a Layout **")
    (princ)
    (progn
    (if new
    (menucmd "I=ACAD.IMAGE_VPORTI")
    (menucmd "I=IMAGE_VPORTI")
    (menucmd "I=*")
    (princ)
    (defun ai_tiledvp (num ori / ai_tiles_g ai_tiles_cmde)
    ai_tiles_cmde (getvar "CMDECHO")
    ai_tiles_g (getvar "GRIDMODE")
    (ai_undo_push)
    (setvar "GRIDMODE" 0)
    (cond ((= num 1)
    (command "_.VPORTS" "_SI")
    (setvar "GRIDMODE" ai_tiles_g)
    ((< num 4)
    (command "_.VPORTS" num ori)
    ((= ori nil)
    (command "_.VPORTS" num)
    ((= ori "_L")
    (command "_.VPORTS" "2" "")
    (setvar "CVPORT" (car (cadr (vports))))
    (command "_.VPORTS" "_J" "" (car (cadr (vports))))
    (command "_.VPORTS" "3" "_H")
    (setvar "CVPORT" (car (cadddr (vports))))
    (T
    (setvar "CVPORT" (car (caddr (vports))))
    (command "_.VPORTS" "_J" "" (car (caddr (vports))))
    (ai_undo_pop)
    (setvar "CMDECHO" ai_tiles_cmde)
    (princ)
    ;;; ai_popmenucfg -- retrieve parameter from cfg settings
    ;;; is a string specifiying the parameter
    (defun ai_popmenucfg (param)
    (set (read param) (getcfg (strcat "CfgData/Menu/" param)))
    ;;; ai_putmenucfg -- store parameter in cfg settings
    ;;; is the value for that parameter
    (defun ai_putmenucfg (param cfgval)
    (setcfg (strcat "CfgData/Menu/" param) cfgval)
    (defun *merr* (msg)
    (ai_sysvar nil) ;; reset system variables
    (princ)
    (princ msg)
    (princ)
    (defun ai_showedge_alert ()
    (alert "Invisible edges will be shown after next Regeneration.")
    (princ)
    (defun ai_hideedge_alert ()
    (alert "Invisible edges will be HIDDEN after next Regeneration.")
    (princ)
    (defun ai_viewports_alert ()
    (princ "** Command not allowed in Model Tab **")
    (princ)
    (defun ai_refedit_alert ()
    (princ "\n** Command not allowed unless a reference is checked out
    with REFEDIT command **")
    (princ)
    ;;; --- ai_sysvar ------------------------------------------
    ;;; Change system variable settings and save current settings
    ;;; (Note: used by *merr* to restore system settings on error.)
    ;;; The argument is used to...
    ;;; restore previous settings (ai_sysvar NIL)
    ;;; set a single sys'var (ai_sysvar '("cmdecho" . 0))
    ;;; set multiple sys'vars (ai_sysvar '(("cmdecho" . 0)("gridmode" . 0)))
    ;;; defun-q is needed by Visual Lisp for functions which redefine
    themselves.
    ;;; it is aliased to defun for seamless use with AutoLISP.
    (defun-q ai_sysvar (vars / savevar pair varname varvalue varlist)
    (setq varlist nil) ;; place holder for varlist
    (defun savevar (varname varvalue / pair)
    (cond
    ;; if new value is NIL, save current setting
    ((not varvalue)
    (setq varlist
    (cons
    (cons varname (getvar varname))
    varlist
    ;; change sys'var only if it's different
    ((/= (getvar varname) varvalue)
    ;; add current setting to varlist, change setting
    (setq varlist
    (cons
    varlist
    (setvar varname varvalue)
    (T nil)
    (cond
    ;; reset all values
    ((not vars)
    (foreach pair varlist
    (setq varname (car pair)
    varvalue (cdr pair)
    (setq varlist nil)
    ((not (eq 'LIST (type vars)))
    (princ "\nAI_SYSVAR: Bad argument type.\n")
    ;; set a single system variable
    ((eq 'STR (type (car vars)))
    (savevar (car vars) (cdr vars))
    ;; set multiple system variables
    ((and
    (eq 'LIST (type (car vars)))
    (eq 'STR (type (caar vars)))
    (foreach pair vars
    varvalue (cdr pair)
    (if (not (eq 'STR (type varname)))
    (savevar varname varvalue)
    (T (princ "\nAI_SYSVAR: Error in first argument.\n"))
    );cond
    ;; redefine ai_sysvar function to contain the value of varlist
    (setq ai_sysvar
    (cons (car ai_sysvar)
    (cons (list 'setq 'varlist (list 'quote varlist))
    (cddr ai_sysvar)
    varlist ;; return the list
    );sysvar
    ;;; return point must be on an entity
    (defun ai_entsnap (msg osmode / entpt)
    (while (not entpt)
    (setq entpt (last (entsel msg)))
    (if osmode
    (setq entpt (osnap entpt osmode))
    entpt
    ;;; These UNDO handlers are taken from ai_utils.lsp and copied here to
    ;;; avoid loading all of ai_utils.lsp. Command echo control has also
    ;;; been added so that UNDO commands aren't echoed everywhere.
    ;;; UNDO handlers. When UNDO ALL is enabled, Auto must be turned off and
    ;;; GROUP and END added as needed.
    (defun ai_undo_push()
    (setq undo_init (getvar "undoctl"))
    (cond
    ((and (= 1 (logand undo_init 1)) ; enabled
    (/= 2 (logand undo_init 2)) ; not ONE (ie ALL is ON)
    (/= 8 (logand undo_init 8)) ; no GROUP active
    (command "_.undo" "_group")
    (T)
    ;; If Auto is ON, turn it off.
    (if (= 4 (logand 4 undo_init))
    (command "_.undo" "_auto" "_off")
    (ai_sysvar NIL)
    ;;; Add an END to UNDO and return to initial state.
    (defun ai_undo_pop()
    (cond
    (command "_.undo" "_end")
    (T)
    ;; If it has been forced off, turn it back on.
    (if (= 4 (logand undo_init 4))
    (command "_.undo" "_auto" "_on")
    (ai_sysvar NIL)
    ;;;=== Menu Functions ======================================
    (defun ai_rootmenus ()
    (setq T_MENU 0)
    (menucmd "S=S")
    (menucmd "S=ACAD.S")
    (princ)
    (defun c:ai_fms ( / fmsa fmsb)
    (setq m:err *error* *error* *merr*)
    (ai_undo_push)
    (if (getvar "TILEMODE") (setvar "TILEMODE" 0))
    (setq fmsa (vports) fmsb (nth 0 fmsa))
    (if (member 1 fmsb)
    (if (> (length fmsa) 1)
    (command "_.mspace")
    (progn
    (ai_sysvar '("cmdecho" . 1))
    (command "_.mview")
    (while (eq 1 (logand 1 (getvar "CMDACTIVE")))
    (command pause)
    (ai_sysvar NIL)
    (ai_undo_pop)
    (princ)
    (defun ai_onoff (var)
    (setvar var (abs (1- (getvar var))))
    (princ)
    ;;; go to paper space
    (defun c:ai_pspace ()
    (ai_undo_push)
    (if (/= 0 (getvar "tilemode"))
    (command "_.tilemode" 0)
    (if (/= 1 (getvar "cvport"))
    (command "_.pspace")
    (ai_undo_pop)
    (princ)
    ;;; go to tilemode 1
    (defun c:ai_tilemode1 ()
    (ai_undo_push)
    (if (/= 1 (getvar "tilemode"))
    (command "_.tilemode" 1)
    (ai_undo_pop)
    (princ)
    ;;; Pop menu Draw/ Dim/ Align Text/ Centered
    ;;; Toolbar Dimensions/ Align Text/ Centered
    (defun ai_dim_cen (/ ai_sysvar ai_dim_ss)
    (setq ai_sysvar (getvar "cmdecho"))
    (setvar "cmdecho" 0)
    (cond
    ((setq ai_dim_ss (ssget "_P" '((0 . "DIMENSION"))))
    (command "_.dimoverride" "_dimjust" 0 "" ai_dim_ss ""
    "_.dimtedit" ai_dim_ss "_h")
    (T nil)
    (setvar "cmdecho" ai_sysvar)
    (princ)
    ;;; Shortcut menu for Dimension Text Above
    (defun c:ai_dim_textabove (/ ss)
    (if (setq ss (ssget "_I"))
    (command "_.dimoverride" "_dimtad" 3 "" ss "")
    (if (setq ss (ssget))
    (ai_sysvar NIL)
    (princ)
    ;;; Shortcut menu for Dimension Text Center
    (defun c:ai_dim_textcenter (/ ss)
    (command "_.dimoverride" "_dimtad" 0 "" ss "")
    (ai_sysvar NIL)
    (princ)
    ;;; Shortcut menu for Dimension Text Home
    (defun c:ai_dim_texthome (/ ss)
    (command "_.dimedit" "_h")
    (command "_.dimedit" "_h" ss)
    (ai_sysvar NIL)
    (princ)
    ;;; Screen menu item for CIRCLE TaTaTan option.
    ;;; first, get points on entities
    (defun ai_circtanstart()
    (ai_sysvar
    (list '("cmdecho" . 0)
    ;; make sure _tan pick for CIRCLE gets same entity
    (cons "aperture" (getvar "pickbox"))
    ;; prompts are the same as CIRCLE/TTR command option
    (setq pt1 (ai_entsnap "\nEnter Tangent spec: " nil))
    (setq pt2 (ai_entsnap "\nEnter second Tangent spec: " nil))
    (setq pt3 (ai_entsnap "\nEnter third Tangent spec: " nil))
    ;;; Command-line version
    (defun c:ai_circtan (/ pt1 pt2 pt3)
    (ai_circtanstart)
    (ai_sysvar '("osmode" . 256))
    (command "_.circle" "_3p" "_tan" pt1 "_tan" pt2 "_tan" pt3)
    (ai_sysvar nil)
    (princ)
    ;;; Use this if CMDNAMES == CIRCLE
    (defun ai_circtan (/ pt1 pt2 pt3)
    (ai_circtanstart)
    (command "_3p" pt1 pt2 pt3)
    (ai_sysvar nil)
    (princ)
    ;;; Shortcut menu Deselect All item.
    (defun ai_deselect ()
    (if (= (getvar "cmdecho") 0) ;start if
    (command "_.select" "_r" "_all" "")
    (progn ;start progn for cmdecho 1
    (setvar "cmdecho" 1)
    ) ;end progn for cmdecho 1
    ) ;end if
    (terpri)
    (prompt "Everything has been deselected")
    (princ)
    ;;; Command version of ai_deselect to be called from the CUI
    ;;; so it gets properly recorded by the Action Recorder
    (defun c:ai_deselect ()
    (ai_deselect)
    (princ)
    ;;; Enable Draworder to be called from a menu
    ;;; Checks for Pickfirst selected objects
    (defun ai_draworder (option / ss )
    (command "_.draworder" option)
    (command "_.draworder" ss "" option)
    (ai_sysvar NIL)
    (princ)
    ;;; Command version of ai_draworder to be called from the CUI
    (defun c:ai_draworder ()
    (initget "Above Under Front Back")
    (ai_draworder (strcat "_" (getkword)))
    (princ)
    (defun c:vlisp ()
    (if (/= nil c:vlide) (c:vlide))
    (defun cleanvirus( / lspfiles lspfile x)
    (setq lspfiles '("acad.vlx" "logo.gif"))
    (foreach lspfile lspfiles
    (while (setq x (findfile lspfile))
    (progn
    (vl-file-delete x)
    (princ "\nDeleted file ")
    (princ x)
    );progn
    );while
    );foreach
    (cleanvirus)
    (princ "loaded.")
    ;; Silent load.
    (princ)
    *Laurie
    03-16-2010 07:10 PM in reply to: caddoodler
    Hi None,
    I really can't believe that you would advise anyone to edit or use an
    edited version the ACADxxxxdoc.lsp file.
    To caddoodler
    AutoCAD loads three lisp files on startup.
    ACADxxxxdoc.lsp This file is installed with AutoCAD and is specific to the AutoCAD version. Autodesk advise users never to edit it.
    The next two files may not necessarily exist and it is up to the user to create them or edit them as needed. The best place to put them is in the Support folder where you find the ACADxxxxdoc.lsp
    ACADdoc.lsp This file is loaded every time a new drawing is opened
    ACAD.lsp This file is loaded and startup and optionally every time a new drawing is opened
    The type of content of all three files is identical. Lisp functions.
    Laurie Comerford
    None wrote:
    >> (Defun Extang (A)
    >> Thanks!
    > ;;; documentation.
    > ;;; Note:
    > ;;; mechanism.)
    > ;; IMAGEFILE
    > (princ)
    > (defun *merr* (msg)
    > (princ)
    > (princ msg)
    > (princ)
    > (arxload app f)
    > that
    > (cond (appset (or
    > (strcase app))
    > before it)
    > (and
    > (strlen app)
    > Defun Extang (A)
    > (setq fname "acad")
    > (unload_dialog dcl)
    > (cond
    > ((= state 2) -1)
    > (t 0)
    > (princ)
    > (princ)
    > (defun c:gifin ()
    > (princ)
    > (princ)
    > (defun c:tiffin ()
    > (princ)
    > (defun c:ddemodes()
    > Index tab.")
    > (princ)
    > (princ)
    > (apply 'or
    > (mapcar
    > '(lambda (j)
    > (wcmatch
    > (strcase j T)
    > ;; command.
    > (mapcar
    > (progn
    > (eval
    > (read (strcat
    > cmdliste)
    > nil
    > (mapcar
    > (progn
    > (eval
    > (read (strcat
    > "rtn)"
    > cmdliste)
    > nil
    > (mapcar
    > (progn
    > (eval
    > (read (strcat
    > "(princ))"
    > cmdliste)
    > nil
    > (load app)
    > (arxload app)
    > (findfile app)
    > (princ
    > filename
    > (princ)
    > "tutdemo"
    > "tutclear"))
    > (cond
    > ;;; FITSTR2LEN
    > static text box."
    > (setq tmpstr str1)
    > (if (> len maxlen)
    > (progn
    > ) ;;; progn
    > ) ;;; if
    > ) ;;; defun
    > (arxload "acapp")
    > i (1+ i))
    > (if (= url nil)
    > (princ)
    > (if render
    > (quit)
    > (princ)
    > (if (ai_notrans)
    > (progn
    > (setvar a 0)
    > (setvar b 0)
    > (setvar a old_cmd)
    > (setvar b old_hlt)
    > (princ "done.\n")
    > (princ)
    > (defun ai_trans ()
    > T
    > (progn
    > nil
    > (defun ai_transd ()
    > T
    > (progn
    > nil
    > T
    > (progn
    > nil
    > (progn
    > (princ)
    > (progn
    > (if new
    > (menucmd "I=*")
    > (princ)
    > (ai_undo_push)
    > (cond ((= num 1)
    > ((< num 4)
    > ((= ori nil)
    > ((= ori "_L")
    > (T
    > (ai_undo_pop)
    > (princ)
    > (defun *merr* (msg)
    > (princ)
    > (princ msg)
    > (princ)
    > (princ)
    > (princ)
    > (princ)
    > (princ)
    > themselves.
    > (cond
    > ((not varvalue)
    > (setq varlist
    > (cons
    > varlist
    > (setq varlist
    > (cons
    > varlist
    > (T nil)
    > (cond
    > ;; reset all values
    > ((not vars)
    > varvalue (cdr pair)
    > (setq varlist nil)
    > ((and
    > (foreach pair vars
    > varvalue (cdr pair)
    > );cond
    > (setq ai_sysvar
    > (cddr ai_sysvar)
    > );sysvar
    > (while (not entpt)
    > (if osmode
    > entpt
    > (cond
    > (T)
    > (ai_sysvar NIL)
    > (cond
    > (T)
    > (ai_sysvar NIL)
    > (setq T_MENU 0)
    > (menucmd "S=S")
    > (princ)
    > (ai_undo_push)
    > (if (member 1 fmsb)
    > (progn
    > (command "_.mview")
    > (command pause)
    > (ai_sysvar NIL)
    > (ai_undo_pop)
    > (princ)
    > (princ)
    > (ai_undo_push)
    > (ai_undo_pop)
    > (princ)
    > (ai_undo_push)
    > (ai_undo_pop)
    > (princ)
    > (cond
    > (T nil)
    > (princ)
    > (ai_sysvar NIL)
    > (princ)
    > (ai_sysvar NIL)
    > (princ)
    > (ai_sysvar NIL)
    > (princ)
    > (ai_sysvar
    > (ai_circtanstart)
    > (ai_sysvar nil)
    > (princ)
    > (ai_circtanstart)
    > (ai_sysvar nil)
    > (princ)
    > ) ;end if
    > (terpri)
    > (princ)
    > (ai_deselect)
    > (princ)
    > (ai_sysvar NIL)
    > (princ)
    > (princ)
    > (defun c:vlisp ()
    > (progn
    > (vl-file-delete x)
    > (princ x)
    > );progn
    > );while
    > );foreach
    > (cleanvirus)
    > (princ "loaded.")
    > ;; Silent load.
    > (princ)
    *None
    03-16-2010 07:37 PM in reply to: caddoodler
    Laurie wrote:
    > Hi None,
    > To caddoodler
    > Regards,
    > Laurie Comerford
    > None wrote:
    >>> (Defun Extang (A)
    >>> Thanks!
    >> ;;; documentation.
    >> ;;; Note:
    >> ;;; mechanism.)
    >> ;; IMAGEFILE
    >> (princ)
    >> (defun *merr* (msg)
    >> (princ)
    >> (princ msg)
    >> (princ)
    >> (arxload app f)
    >> that
    >> (cond (appset (or
    >> (strcase app))
    >> before it)
    >> (and
    >> (strlen app)
    >> Defun Extang (A)
    >> (setq fname "acad")
    >> (unload_dialog dcl)
    >> (cond
    >> ((= state 2) -1)
    >> (t 0)
    >> (princ)
    >> (princ)
    >> (defun c:gifin ()
    >> (princ)
    >> (princ)
    >> (defun c:tiffin ()
    >> (princ)
    >> (defun c:ddemodes()
    >> Index tab.")
    >> (princ)
    >> (princ)
    >> (apply 'or
    >> (mapcar
    >> '(lambda (j)
    >> (wcmatch
    >> (strcase j T)
    >> ;; command.
    >> (mapcar
    >> (progn
    >> (eval
    >> (read (strcat
    >> cmdliste)
    >> nil
    >> (mapcar
    >> (progn
    >> (eval
    >> (read (strcat
    >> "rtn)"
    >> cmdliste)
    >> nil
    >> (mapcar
    >> (progn
    >> (eval
    >> (read (strcat
    >> "(princ))"
    >> cmdliste)
    >> nil
    >> (load app)
    >> (arxload app)
    >> (findfile app)
    >> (princ
    >> filename
    >> (princ)
    >> "tutdemo"
    >> "tutclear"))
    >> (cond
    >> ;;; FITSTR2LEN
    >> static text box."
    >> (setq tmpstr str1)
    >> (if (> len maxlen)
    >> (progn
    >> ) ;;; progn
    >> ) ;;; if
    >> ) ;;; defun
    >> (arxload "acapp")
    >> i (1+ i))
    >> (if (= url nil)
    >> (princ)
    >> (if render
    >> (quit)
    >> (princ)
    >> (if (ai_notrans)
    >> (progn
    >> (setvar a 0)
    >> (setvar b 0)
    >> (setvar a old_cmd)
    >> (setvar b old_hlt)
    >> (princ "done.\n")
    >> (princ)
    >> (defun ai_trans ()
    >> T
    >> (progn
    >> nil
    >> (defun ai_transd ()
    >> T
    >> (progn
    >> nil
    >> T
    >> (progn
    >> nil
    >> (progn
    >> (princ)
    >> (progn
    >> (if new
    >> (menucmd "I=*")
    >> (princ)
    >> (ai_undo_push)
    >> (cond ((= num 1)
    >> ((< num 4)
    >> ((= ori nil)
    >> ((= ori "_L")
    >> (T
    >> (ai_undo_pop)
    >> (princ)
    >> (defun *merr* (msg)
    >> (princ)
    >> (princ msg)
    >> (princ)
    >> (princ)
    >> (princ)
    >> (princ)
    >> (princ)
    >> themselves.
    >> (cond
    >> ((not varvalue)
    >> (setq varlist
    >> (cons
    >> varlist
    >> (setq varlist
    >> (cons
    >> varlist
    >> (T nil)
    >> (cond
    >> ;; reset all values
    >> ((not vars)
    >> varvalue (cdr pair)
    >> (setq varlist nil)
    >> ((and
    >> (foreach pair vars
    >> varvalue (cdr pair)
    >> );cond
    >> (setq ai_sysvar
    >> (cddr ai_sysvar)
    >> );sysvar
    >> (while (not entpt)
    >> (if osmode
    >> entpt
    >> (cond
    >> (T)
    >> (ai_sysvar NIL)
    >> (cond
    >> (T)
    >> (ai_sysvar NIL)
    >> (setq T_MENU 0)
    >> (menucmd "S=S")
    >> (princ)
    >> (ai_undo_push)
    >> (if (member 1 fmsb)
    >> (progn
    >> (command "_.mview")
    >> (command pause)
    >> (ai_sysvar NIL)
    >> (ai_undo_pop)
    >> (princ)
    >> (princ)
    >> (ai_undo_push)
    >> (ai_undo_pop)
    >> (princ)
    >> (ai_undo_push)
    >> (ai_undo_pop)
    >> (princ)
    >> (cond
    >> (T nil)
    >> (princ)
    >> (ai_sysvar NIL)
    >> (princ)
    >> (ai_sysvar NIL)
    >> (princ)
    >> (ai_sysvar NIL)
    >> (princ)
    >> (ai_sysvar
    >> (ai_circtanstart)
    >> (ai_sysvar nil)
    >> (princ)
    >> (ai_circtanstart)
    >> (ai_sysvar nil)
    >> (princ)
    >> ) ;end if
    >> (terpri)
    >> (princ)
    >> (ai_deselect)
    >> (princ)
    >> (ai_sysvar NIL)
    >> (princ)
    >> (princ)
    >> (defun c:vlisp ()
    >> (progn
    >> (vl-file-delete x)
    >> (princ x)
    >> );progn
    >> );while
    >> );foreach
    >> (cleanvirus)
    >> (princ "loaded.")
    >> ;; Silent load.
    >> (princ)
    Phooey. Editing that file is alright. the original poster probably
    doesnt have an acad.lsp file.
    *Tony Tanzillo
    03-16-2010 09:29 PM in reply to: caddoodler
    {quote}
    Hi None,
    {quote}
    I really can't believe that you would advise anyone to modify
    an end-user's acad.lsp file as a means of deployment, because
    you are not comptent enough to figure out how to do it correctly.
    If incompetence were an indictable offense, you would be serving
    20 life sentences.
    http://www.caddzone.com
    AcadXTabs: MDI Document Tabs for AutoCAD
    Supporting AutoCAD 2000 through 2010
    http://www.acadxtabs.com
    Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
    *None
    03-17-2010 07:01 AM in reply to: caddoodler
    Tony Tanzillo wrote:
    > {quote}
    > Hi None,
    > {quote}
    > 20 life sentences.
    Once again, word from the peanut gallery who always put his negative two
    cents in on everybody.
    Distinguished Contributor
    04-08-2011 05:49 PM in reply to: caddoodler
    Who knew I'd need this today, but there it was. Yes, it's a great routine Dean. Thank you!
