• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    *Murph
    Re: Text Lisp routine needed for merging text styles..
    03-12-2010 03:48 AM in reply to: caddoodler
    There's is nothing on my blog if you are referring to that as the site.
    There is a set of tools in AutoCAD named CAD Standards, look on the ribbon
    on the Tools tab.
    Murph
    http://map3d.wordpress.com/
    "CADDoodler" wrote in message news:6353511@discussion.autodesk.com...
    OK that's alot of info...i'll begin to digest that sites info and try to
    find the answer to my question.
    TY for your time and insight :smileyhappy:
    Please use plain text.
    *Dean Saadallah
    03-12-2010 05:09 AM in reply to: caddoodler
    ZIP contains two files, place them in AutoCAD's search path, then drag and
    drop the LSP file into an open DWG you want to fix, type TXTMRG and watch
    the pop-up and command line for instructions.
    How to load and run Lisp files is explained everywhere, look around if you
    need guidance. If you have to ask a lot of questions about this tool, delete
    both files and come back here for another fix from someone else :smileyhappy:)
    Dean Saadallah
    http://LTisACAD.blogspot.com
    *None
    03-12-2010 06:43 AM in reply to: caddoodler
    Murph wrote:
    > None, It's missing a function when I ran it.
    Funny - works for me.
    *None
    03-12-2010 06:44 AM in reply to: caddoodler
    Works for me!
    *Murph
    03-12-2010 06:50 AM in reply to: caddoodler
    May be you have the EXTANG function load from your startup. :smileyhappy:
    ; error: no function definition: EXTANG
    Murph
    wrote in message news:6353775@discussion.autodesk.com...
    *None
    03-12-2010 08:37 AM in reply to: caddoodler
    You are absolutely correct. I didn't realize it, but I have the
    following in my acad.lsp:
    (Defun Extang (A)
    (Setq A (Tblsearch "STYLE" A))
    (Setq J (Cdr (Assoc 50 A)))
    *None
    03-12-2010 08:38 AM in reply to: caddoodler
    CADDoodler wrote:
    > I want to TY in advance for your time spent working with me....
    > When i try and open that LISP file using notepad i get a bunch of jibberish headed with the message: "AUTOCAD PROTECTED LISP FILE".
    > Am I doing something wrong in trying to view/read it?
    Add the following to your startup:
    (Defun Extang (A)
    Then load chgsty.lsp and it will work.
    *Dean Saadallah
    03-12-2010 11:42 AM in reply to: caddoodler
    It works great, thanks to it's author (not me): another excellent tool found
    in these discussion areas, worth sharing.
    Dean Saadallah
    *None
    03-12-2010 02:14 PM in reply to: caddoodler
    Me - You are welcome.
    Active Member
    03-16-2010 03:54 PM in reply to: caddoodler
    Yes after I dropped the .lsp file into my acad drawing, I tried to run it and it keeps giving me that "; error: no function definition: EXTANG" error prompt. Please bare with me and explain to me how to fix this error and get the .lsp routine to work. I am a BEGINNER at .lsp files..as a matter of fact this will be my 1st time ever installing and running one. Thank you in advance for your time in answering my questions.
