• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    New Member
    Tables Roundingup figures
    102 Views, 2 Replies
    10-18-2011 01:17 AM
    We have a number of table in a template, the typical values that are required are too 1, 2 or 3 decimal places (i.e 1.1, 1.12 or 1.123).
    If we have the units (of the drawing) set to 0.0 then it rounds all inputs to 1 decmical place (i.e 1.1 even if we put 1.123).
    If we have the units set to 0.000 then it shows all inputs to 3 decimcal places, including 1.1 is shown as 1.100.
    Is there a way of showning just the figured typed (similar to excel) i.e 1.2 is shown as 1.2 NOT 1.200)
    Thank you
    Please use plain text.
    Product Support
    Re: Tables Roundingup figures
    10-18-2011 07:00 PM in reply to: markfarrell
    You might need create new Cell Styles for different precision data cells. Per you example, you could create 3 Cell Styles for 1,2,3 decimal data cells respectively in TableStyle command, then assign the Cell Styles to corresponding cells. Now, the data precision in these cells will not be affected by drawing units.
    The step to create new Cell Styles and set precession for Cell Styles is show in the attached JPG.
    Cell Styles
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    黄庆九
    Qingjiu Huang
    Support Specialist
    Product Support
    AntiBanana
    10-18-2011 08:19 PM in reply to: huangq
    Hello, i'm newbie here. i dunno how to create new post so i ask here.
    I tried to print the layout from autocad, the autocad will freeze and it will prompt out the AutoCAD Application error message as the attachment below. Once click on "cancel", the application will shut down itself. Anyone can help me pls!!
    *The printer is HP LaserJet P5225.
    *Other program like Revit, MS Word and etc still able to print well.
    Appreciate a lot.
