• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    TEXT POSITION FOR ED COMMAND
    215 Views, 6 Replies
    05-25-2012 07:32 AM
    Hi everybody,
    I'm using the ED command in AutoCAD 2012. I have my texts verticals, but I want to edit them in horizontal position, however when I active the command and I select the text, the edit option appears in vertical position. What can I do to control this option? Is there some variable to control this option?
    Thank you for your help.
    Please use plain text.
    Patchy
    Re: TEXT POSITION FOR ED COMMAND
    05-25-2012 07:34 AM in reply to: carlos.arredondo
    You're using a font with @ infront of the font name right?
    If you do , DON'T.
    05-25-2012 08:00 AM in reply to: Patchy
    Thanks!
    This happen with any text font.
    Patchy
    05-25-2012 08:04 AM in reply to: carlos.arredondo
    Any font :smileysurprised:
    Attach .dwg here and let's see.
    05-25-2012 08:37 AM in reply to: carlos.arredondo
    Hi, the font is ROMANS. However, It only happen in a specific machine, because I try in any other PC but doesn't happen that.
    05-25-2012 09:15 AM in reply to: carlos.arredondo
    What is your MTEXTFIXED system variable set at? Sounds like it might be set on 0 or 1. Try changing it to 2 and see if the text editor works the way you want it to.
    The MTEXTFIXED system variable sets the display size and orientation of multiline text in a specified text editor.
    Type:Integer
    Saved in:Registry
    Initial value:2
    If MTEXTED is set to “Internal,” multiline text is displayed in the In-Place Text Editor, and the setting of MTEXTFIXED has the following results:
    0 or 1
    Displays the In-Place Text Editor and the text within it at the size, position, and rotation of the multiline text object in the drawing.
    2
     Text that would otherwise be difficult to read (if it is very small, very large, or is rotated) is displayed at a legible size and is oriented horizontally so that you can easily read and edit it.
    05-25-2012 09:40 AM in reply to: Johneng
    I had solved the doubt, however thank you so much for your valuable answer.
