AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
TABLE BREAK PROBLEM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've inserted a table using a data link to an excel file. I've enabled breaking and repeat top labels. When I break the table into two, it does not repeat the header row. I've gone into the table and noticed that the header row is set to data so I changed that to header and still no luck. I can split a table if I create it from scratch but not from an excel file. Seems odd, must be a glitch?
Re: TABLE BREAK PROBLEM
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
davidm
Did you ever get this issue resolved?
I am seeing the same problem in AutoCAD Map 2011.
Jason
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Same problem here. Any luck anyone?
Josh
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have seen this issue across these forums before. I just worked around it by either copying the top label cells to the split table or creating a new table and just using the range option to insert the top labels. I just can't remember which at the moment. I know this doesn't fix it but I wasted more time searching for a solution than just doing what I had to do to get the job done. HTH.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have since discovered that if you set the ROW STYLE to Header (not the individual cell styles) than it works as it should.
Jason
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Jason. That did the trick. I had been trying to select the row(s) and right click but the format options were grayed out. I just needed to look at the properties list for row style instead.
