AutoCAD 2010/2011/2012 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Superhatch Questions
- Highlight
- Email to a Friend
- Report Inappropriate Content
Ok so I have several questions on the superhatch command. I havent been able to figure it out and I dont know if it has to do with my computer resolution (using a laptop and its windows vista) or what but Im hoping someone can help me out with these questions!
1. when superhatching I am noticing in the pdf that the colors look pixelated and they are bleeding into other objects (a floor polan and bleeding into the white dining table). But when I look at it from paperspace it looks fine. I am going into benjamin moore and dupont and saving a texture then superhatching that texture into my drawing.
2. When you superhatch lets say an entire floorplan and you turn off tframes (to not show the lines) it also turns off all the lines you did to make you drawing in the first place. So I tried to block the entire object before I superhatched it and then place the blocked object over but it just disappears behind the textures. Do I have to go into paperspace and redraw the detail overtop?
3. There are white lines that show in random spots on the drawing as I zoom in and out once I have superhatched. How do I get rid of these? I have heard that possible opening up the pdf into photoshop then overwriting the existing file and that helps.
4. Dont think this is an exact cad question but the colors look completly different from the pdf I see on my laptop and what actually gets printed. If I go to a website and copy and paste a texture in, it comes out a different shade. Is this because I dont have a strong resolution on my laptop?? How do I make the colors come out the same as you see it on the website?
Thanks!
Re: Superhatch Questions
- Highlight
- Email to a Friend
If you have Photoshop, why not do this pattern there? do you need it to be inside AutoCAD? Are these paint textures?
I believe both companies offer Photoshop colors and textures for your use, or at least they used to do so.
What PDF driver are you using? Can you share a PDF with the problem?
No two computers will display colors exactly 100% identical: plsu there is the whole calibration with the printer thing required for every PC, and well, it just becomes a horrible mess for the inexperienced. If you've ever received a professional color image there is always a small disclaimer attached about color output. IMHO, you only color and show off an image on the one and only computer, unless you plan on adjusting them all when you switch computers.
- Highlight
- Email to a Friend
Thanks for the reply. Some of them are paint textures others are corian and zodiak granite pieces and then I have some fabirc textures. I guess I dont have to do it in cad, I will try photoshop but in autocad it allows you to snap to a corner, I dont think you can do this in photoshop. Can you? I just want to make sure that when it gets printed off you dont see any white spots.
I have adobe for my PDF's.
So if I was to get a higher resoultion laptop would this at least help with the pixelation and show the colors a bit better? Or will the pixelation leave once I do it in photoshop?
- Highlight
- Email to a Friend
You need highest quality images to get high quality output from any program, Photoshop or AutoCAD.
If all you are doing is grabbing the screen image on those websites to use in your files you will find they are low res 150x150 pixel 85kb that will not work for high end output. No computer spec is going to fix that:
http://www2.dupont.com/Surfaces/en_US/products/cor
- Highlight
- Email to a Friend
Ok thanks so much. With superhatching when I put the textures in and turned off tframes it also got rid of the existing lines I made (for example a hutch) so all its showing is color but its not in any outlined shape. Is there a way to bring those lines out in autocad? I have to turn off tframes since its creating these boundary lines when I try to superhatch around a free flowing object for example an oven and putting a stainless steel texure around the glass part.
I am pretty sure it would work in photoshop ( I could put the drawing layer in front of the texutures layers) but how do I do this in autocad?
- Highlight
- Email to a Friend
Highlight the lines that you want to be on top. Right-click and select draw order then bring to front.
Also highlight your hatch, right-click, draw order, send to back just to make sure.
- Highlight
- Email to a Friend
It worked! Thank you so much!!
