• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    brunobiazotti
    Accepted Solution
    Subtract objects created with "region"
    341 Views, 8 Replies
    08-15-2012 06:19 AM
    Hi everybody!
    One easy way for I calculate the weight of plates with many holes is creating regions and subtract the cuts as i need and after apply "LIST" command for get value of area . But, i cannot subtract the regions, in command line says :
    "Command: region
    Select objects: Specify opposite corner: 44 found
    Select objects:
    44 loops extracted.
    44 Regions created.
    Command: subtract Select solids, surfaces, and regions to subtract from ..
    Select objects: 1 found
    Select objects: Select solids, surfaces, and regions to subtract ..
    Select objects: Specify opposite corner: 4 found
    Select objects:
    At least two solids, surfaces, or coplanar regions must be selected."
    Why? what i do?
    I appreciate any answer!
    Please use plain text.
    *Expert Elite*
    Re: Subtract objects created with "region"
    08-15-2012 06:58 AM in reply to: brunobiazotti
    Attach the file here that exhibits this behavior.
    brunobiazotti
    08-15-2012 08:51 AM in reply to: JDMather
    SugarCAD
    08-15-2012 09:28 AM in reply to: brunobiazotti
    You need to put them all at elevation 0.
    *Expert Elite*
    Patchy
    08-15-2012 09:34 AM in reply to: brunobiazotti
    Nothing wrong with it.
    *Expert Elite*
    Patchy
    08-15-2012 09:38 AM in reply to: SugarCAD
    Did you find any entities with elevation other than zero? I must have missed them.
    brunobiazotti
    08-15-2012 10:14 AM in reply to: Patchy
    Yes, out of zero elevation. I not understand what happening. I check in the properties of the circles and show me that's ok ZERO, but is lie. The properties not show me the true value of the zero, the accuracy goes beyond that the display of the properties can show me.
    SugarCAD
    08-15-2012 12:04 PM in reply to: brunobiazotti
    Not really sure, but I ran "All to Zero" macro and it worked.
    Just add this to a button
    ^C^C_UCS;;_move _all;;0,0,1e99;;_move _all;;0,0,-1e99;;_chprop;_all;;_thickness;0;;^M;
    *Expert Elite*
    08-15-2012 12:52 PM in reply to: brunobiazotti
    brunobiazotti wrote:
     I check in the properties of the circles and show me that's ok ZERO, ...
    Did you check out to 8 decimal places?
