• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    Struggling with Limit Dimensioning, MMC, LMC ect..
    91 Views, 3 Replies
    02-04-2013 06:30 PM
    Hello, New to the message board, but I am a student studing Mechanical Engineering.  I am struggling with MMC, LMC, Tolarance, Allowance. and using plus-minus, single limit, limit dimensions.  I am using 2012 AutoCad.  If anyone knows a place online that can better describe these, and help me with using them on drawings that would be wonderful.
    Please use plain text.
    Valued Mentor
    leothebuilder
    Re: Struggling with Limit Dimensioning, MMC, LMC ect..
    02-05-2013 06:41 AM in reply to: jessser84
    On the dimension toolbar select "Tolerance" which brings up the Geometric Tolerance dialog box. Is that what you're after ?
    Valued Mentor
    02-05-2013 07:48 AM in reply to: jessser84
    Check out this tutorial:
    http://www.youtube.com/watch?v=PQP6ZOKNHq0
    GrantsPirate
    02-05-2013 09:01 AM in reply to: jessser84
    For the dimensions you will create different dim styles for each of those that you listed, you might need several of each.
    Use Tolerance command for the actual Feature Control Frame.
    For Datums create one in Mulitleaders, that is what I have done.
    For understanding GD&T without specific questions it is too wide open to help you.
