• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Valued Mentor
    JohnHolder
    Accepted Solution
    Strange graphical error
    747 Views, 9 Replies
    04-08-2011 03:05 PM
    As the picture shows... the points and one of the lines I drew ( just a temp construction line - which I am gizmo draging during the screen shot ) has line comming off of them.  ( also happening to the gizmo and the tips of regular lines )
    this just started happening in the drawing a couple days ago.   Not sure what exactly happened to cause it.
    if I save / shut down Acad, then restart it goes away for a short time then comes back.
    also, when I zoom to extent, some of the construction lines do not show up - just 1/2 of line.  not all just a couple.
    then when I zoom in/out they are fully drawn.
    so first I checked to see if I had the latest drivers, I didn't and updated.  same problem.
    anyone have this happen before or have any suggestions on what could cause it?
    win 7 64bit
    Autocad 2012
    2.8GHz I7 quad
    Nvidia FX1800
    12gig ram.
    An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
    "Do or do not... there is no try"
    Master Yoda.
    Please use plain text.
    Valued Mentor
    Re: Strange graphical error
    04-09-2011 01:14 PM in reply to: JohnHolder
    a graphic card drivers issue perhaps
    Valued Mentor
    JohnHolder
    04-09-2011 01:31 PM in reply to: mrkaplan
    Unlikely. I just stared working on another drawing for the same project.  it's just showing up on that one drawing.
    it's really strange.
    Master Yoda.
    Valued Mentor
    04-10-2011 01:38 AM in reply to: JohnHolder
    have you tried
    auditing the dwg , switching visual styles 2d wireframe / 3d wireframe
    if that fails you can try wblock the model
    Valued Mentor
    JohnHolder
    04-10-2011 11:53 AM in reply to: mrkaplan
    it's happening to another drawing now too....  Audit finds no errors.  it does go away when I switch to 2d wireframe instead of wireframe or 3d wireframe.  The only problem with that is the flicker when you rotate the screen or 3d rotate anything.
    I'll try wblock the model next.
    Master Yoda.
    Distinguished Mentor
    jaich
    04-11-2011 12:27 PM in reply to: JohnHolder
    Video card driver up to date?
    Valued Mentor
    JohnHolder
    04-11-2011 12:30 PM in reply to: jaich
    "so first I checked to see if I had the latest drivers, I didn't and updated.  same problem."
    Master Yoda.
    Valued Mentor
    JohnHolder
    04-26-2011 11:22 AM in reply to: JohnHolder
    Hardware acceleration was the problem.  I had to turn it off and now it works without the glitch.
    Master Yoda.
    Member
    ahj24
    05-04-2011 10:22 AM in reply to: JohnHolder
    This happened to me too, when I restarted my computer it resolved.
    Member
    miteneks
    07-11-2011 07:39 AM in reply to: JohnHolder
    I have the same problem, with a Quadro 4000, driver version. 8.17.12.7061.
    I wonder if it is specifically a Quadro driver problem. Anyone with other cards seeing the same thing?
    Disabling hardware acceleration seems to be the only solution.
