• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    force87
    Step file import/ export AutoCAD 2012 and Inventor Fusion 2012
    6438 Views, 6 Replies
    12-29-2011 10:04 AM
    Hello everybody,
    I draw a 3D model with colours in AutoCAD 2012 and  save it in .dwg file. After that I open this file with Inventor Fusion 2012, I see the model and export it in .step format. When I open this .step in Fusion 2012 or in other program  (Altium Designer 2010)  colours are lost.... Everything is grey..... I want to keep the colours of my 3D model.
    Is it possible? Do I use a wrong settings? Where can I modify?
    Can Fusion 2012 export in AP214 step format and keep the colours?
    I enclosed some files....
    I open the.step files and I write a random values to RGB_COLOURS row, save as it  and  so Fusion can open and visualize the new file with colours (not grey!).
    The question: Why can not I save .step files with colours?
    Thanks.
    Viktor
    Please use plain text.
    Product Support
    Re: Step file import/ export AutoCAD 2012 and Inventor Fusion 2012
    01-04-2012 07:31 AM in reply to: force87
    Hi Victor,
    as far as I can tell Inventor Fusion currently does not seem to support keeping the color in the export.
    I will get some clarification from our developers on this and will let you know the result.
    Best regards,
    Silvia
    Silvia Menon
    Support Specialist
    Product Support
    http://www.autodesk.com/autocad-support
    Product Support
    01-05-2012 03:15 AM in reply to: Simenon
    Your AutoCAD 3D model is only a single solid with the faces coloured.
    When you import into Fusion, it sees the model as one solid and therefore only the base colour will be shown.
    If I create a multiple solid part in AutoCAD and assign different materials, now when you import into Fusion the materials are retained.
    Jon
    Jon Dean
    Support Specialist
    Product Support
    New Member
    force87
    01-06-2012 12:11 PM in reply to: force87
    How can I make multiple solid? Print Screen, example, etc
    Can you send me your dwg file? Thanks.
    Product Support
    01-10-2012 02:08 AM in reply to: force87
    Although you can import the DWG into Fusion and maintain Colour / Material, if you then export to STEP we lose the properties. I must have missed out an operation when I first tested this.
    I will log the issue with development.
    Jon
    Jon Dean
    Support Specialist
    Product Support
    New Member
    11-07-2012 05:35 PM in reply to: force87
    Hi There,
    I am a Tekla 3D user. One of my client use their design 3D Inventor. I try to import their model from Inventor to my Tekla. I want to know if   Inventor has *.ifc, *.SDNF, *.STEP format of export file.
    David Bao
    11-08-2012 01:24 AM in reply to: dbaoss
    dbaoss wrote:
    ....I want to know if   Inventor has .... *.STEP format of export file.
    David Bao
    Yes.
