AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Squeezed Text in an Block
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The text in a title block I use keeps being squeezed together everytime I bring it into a new drawing. It is squeezed to the point were it is pushed on to the next line but then it overlaps the text below it. This only happens when I rotate the block to fit a landscape layout. It works fine when it is in portrait.
The text that keeps having the problems is not dynamic. It looks fine in the origanal drawing where the block was created and when I explode it the appears to be enough room.
Does anyone have any ideas on how to fix this?
Attached is the file I am having problems with and a picture of what it is doing. The text is the address in the lower right corner. It is the first line that is having the problem.
Re: Squeezed Text in an Block
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Your photo shows it is not arial font, when I opened your drawing with arial font, no problem at all.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Expand your mtext box and set your text style to middle center on some of the items in your block. Re-examine the mtext and how you want it to act if you need long text strings.
