• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    New Member
    Space bar Commands
    216 Views, 2 Replies
    10-10-2012 10:29 AM
    Hello all,
    I used to be able to simply select a line, PL and or  blocks, hit the letter "E" to erase and then "Space-Bar" and it would erase the object. Now I have to hit the 'E" first then select the object, then hit the space bar. What can I do to set it back to how i used to do it?
    Same thing happens with the Move command.
    Help please
    Please use plain text.
    Valued Contributor
    Re: Space bar Commands
    10-10-2012 12:07 PM in reply to: jgele001
    I think it is the nown / verb selection check box on the selections tab of the Options dialog.
    See attached picture.
    Also can be accessed by typing pickfirst at the command prompt.
    Rick
    Valued Contributor
    CCDesigner
    10-31-2012 11:24 AM in reply to: jgele001
    Make sure PICKFIRST is set to 1
    R. Williams
    AutoCAD 2010 Certified Professional
    <!-- If all else fails hit F1 -->
    ---AutoCAD 2013---
