• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    Sheet Index table issues
    136 Views, 0 Replies
    03-12-2012 12:18 PM
    From Sheet Set Manager, I created a Drawing Index....in order to conform to the project standards I created customized categories that would identify the which phase a new version of the drawing within the set had been issued.
    we have used dots on the prototype, so i had copied a dot "character as the default character.....and then i erased the dot from those sheets (phases) that it did not apply to.
    The dots all show up on the matrix as expected, but what was not expected was that a "--" showed up in an voided cell that I had done prior to updating the link.....
    one solution I believe would work, would be to clear go through all the sheets / customi sheet settings and clear (space bar) through each non-dot value.....which is time consuming and loses the value of programming it into the table in the first place
    any suggestions?
    Please use plain text.
