• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    KevinCassel
    Accepted Solution
    Setting the scale for primary and alt units
    521 Views, 3 Replies
    11-09-2011 06:40 AM
    Im trying to make the promary units metric and the alt to engineering but the scale factor is wrong. It thinks that 6 meters is 1.8288". Any sugestions?
    Please use plain text.
    *Expert Elite*
    Re: Setting the scale for primary and alt units
    11-09-2011 09:15 AM in reply to: KevinCassel
    Correct alt units from metric to engineering is 0.03937007874016.
    By the way, six meters is over 19 feet, no where near the 1.828 inches you said in your post. I don't know where you got that conversion. The closest I can get is 5 centimeters equals 1.96 inches.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    KevinCassel
    11-09-2011 09:43 AM in reply to: tcorey
    I didnt think that was the converion, i said for some reason my dimension thought this was right.
     "Im trying to make the promary units metric and the alt to engineering but the scale factor is wrong. It thinks that 6 meters is 1.8288".
     I know that six meters is 19'-8.22"
    But thanks for the number, although I imported a file with the right conversion and got it that way.
    KevinCassel
    11-09-2011 09:48 AM in reply to: KevinCassel
    And if anyone had the same problem as me, this is how you fix it;
    Format> Dimension Style> Modify
    In the Alternate Unit tab, change the Multiplier for alt units to 39.37007874015748
    1 meter should now be 3'-3.37"
