• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Active Member
    Selection window
    110 Views, 3 Replies
    06-08-2011 01:28 PM
    Is there an easy way to align the selection window with an object?  Say, for instance, I have an object with many entities at 45 degrees closely situated next to other objects.  I want to select ONLY, the object(s) at 45 degrees without selecting the objects adjacent to them.
    Is there a way to rotate the selection window?
    Is there another way to do this?
    Please use plain text.
    Active Member
    LightingDesignAlliance
    Re: Selection window
    06-08-2011 01:36 PM in reply to: lwittstock
    You can use any of the following window functions within a command:
    Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Add/Remove/Multiple/P
    revious/Undo/AUto/SIngle/SUbobject/Object
    You probably want to use WP or CP
    *Pro
    nestly
    06-08-2011 02:11 PM in reply to: lwittstock
    As far as I know, you can't change the angle of the selection window, but you can easily align your view so the angled objects are horizonal or vertical having the same effect as rotating the selection window.
    What you'll probably find more useful are the advanced selection options mentioned above.  To select the object(s) before starting a command, type SELECT at the command line, followed by one of the selection options "WPolygon" "CPolygon" "Fence" etc
    http://www.youtube.com/watch?v=ciEP6gE7Jdc
    Active Member
    06-08-2011 05:25 PM in reply to: nestly
    Thanks to both!!!  I will try the suggestions.
