AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Sections from 3d plines?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi, I have a 3d topographic survey plan. I need to take sections at various locations and would like to know the best way of going about this.
I am used to working with solids and so would normally just take a section plane but this won't work as the 3d topographic survey plan I have is made up of polylines.
Please could you point me in the right direction?
Re: Sections from 3d plines?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Plain Autocad has no way to do it.
Civil 3D will.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
beg to differ - vanilla autocad isn't the easiest way to do it, but....
You could "LOFT" the contour lines to create a surface, use that surface to SLICE a solid cube that is larger than the site and then look at a cut section of the cube along a proposed alignment.... Where there's a will there's a way. I wouldn't rely on it, but it could be done.
This is from an exercise in the Mastering ACAD 2011 book....
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Show me, loft them, then post your result here with a cross section of E-W direction right in the middle of the site.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I cheated & took the sample data from the book (exercise is in Chapter 22, page 714-719 of Mastering 2011....
I'll look at your example when I have time - not sure what will happen with the spaces in the contours from the text labels....
Procedure:
Loft makes you select each contour line in order - fine for the example, where it did not have a local high point....
Then have a rectangle below the "site" & extrude it up beyond the contours
Use the surface from the LOFT to slice the extruded box & only keep the lower portion.
THen I set up a UCS on a y-z plane & created a rectangle on the east-west line & used slice again to cut the surface
Finally "FLATSHOT" the sliced plane to get a section.
I'll have to see how the heck to make it (Loft) work when the contours give peaks & valleys, versus an upslope gradient....
As I said, not my fiirst choice by any means but I was able to get a section line from the flatshot - see below.
C3D 2011
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It all comes to LOFT problem, they will intersect, therefore the reason I said kiss Vanilla good bye to do this task.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try the full working 21-day evaluation of DotSoft's MapWorks Sections. It's a low cost add-on to plain AutoCAD.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I would generally agree. It MIGHT be possible to create a sophisticated surface in sections and "UNION" together... but by when you invest enough time in such a mundane task you've probably wasted enough $$'s to pay for the upgrade to C3D...
Just wanted to point out that there may be a way - not exactly optimal by any means, but it could work - esp given that we don't know how complex the OP's data is....
Cheers!
C3D 2011
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Or if not C3D then a 3rd party add-on capable of the task....
C3D 2011
