• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Mooref3
    Running Multiple AutoCAD Windows
    243 Views, 6 Replies
    06-07-2011 05:40 AM
    I was recently working on a print and forgot to mark down the original dims before making all of the changes. I attempted to open the file again, as a read only, by going to "open with..." and selecting another program. After doing this, AutoCAD now opens a whole new AutoCAD program each time a print is opened. I tend to have multiple drawings open at a time and cycle through them, but am unable to smoothly now. With all of the programs open, my computer starts to bog down.
    Does anyone know of anything I can do to make it so that AutoCAD opens the drawing as a new window vs a new program? It would be greatly appreciated.
    Thank you,
    Fred
    Please use plain text.
    pendean
    Re: Running Multiple AutoCAD Windows
    06-07-2011 05:48 AM in reply to: Mooref3
    SDI variable needs to be set to 0 (that's a zero): see if that helps.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Mooref3
    06-07-2011 05:56 AM in reply to: pendean
    SDI 0 did not work. It was already set to 0
    Distinguished Mentor
    ampster
    06-07-2011 06:07 AM in reply to: Mooref3
    taskbar = 0
    Mooref3
    06-07-2011 06:09 AM in reply to: ampster
    Nope. Taskbar already set to 0 yet again.
    ampster
    06-07-2011 06:21 AM in reply to: Mooref3
    what are .dwg files associated with now?  In either Win7 or WinXP, they should be associated with "AutoCAD DWG Launcher"
    HTH
    Mooref3
    06-07-2011 06:31 AM in reply to: ampster
    BINGO!
    Thank you! It was associated with the .exe file!
    Everythign should work now!! :smileyhappy:
