• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Active Contributor
    Accepted Solution
    Rtext Diesel, cannoscale
    393 Views, 7 Replies
    02-13-2013 06:58 AM
    Dear autocad / lisp users,
    Could somebody please help me.
    I want to create a dynamic block that automaticly updates the viewport cannoscale a.k.a. Plotscale.
    At the moment I / We have a dynamic block that contains a field for the Plotscale.
    The only problem is, we have to fill it in ourselfs. so this means human errors or even blank fields.
    Not so good.
    Is there somebody who might knows a little bit of code to put in a RTEXT - Diesel block?
    I will appreaciate anny help.
    Thank you,
    Michel
    Please use plain text.
    *Expert Elite*
    JGerth
    Re: Rtext Diesel, cannoscale
    02-13-2013 09:43 AM in reply to: weedseed85
    Why not use a FIELD, and use the Viewport object properties?
    Active Contributor
    02-13-2013 11:16 PM in reply to: JGerth
    Thank you for your post.
    I've tried the field command, but with no luck.
    When I put in a FIELD, and choose plotscale, it does not
    update when I change the VpScale. It just stays 1:1
    or a big numer in modelspace.
    I tried several times before but, no luck.
    Active Contributor
    02-14-2013 01:49 AM in reply to: weedseed85
    Try this it took me some time & help to get there, I think this is what J. Gerth is trying to tell you.
    :smileyhappy:
    Active Contributor
    02-14-2013 04:11 AM in reply to: lesleys
    Thats exactly what I was looking for!
    Truely perfect
    Thank you so much!
    Active Contributor
    02-14-2013 05:18 AM in reply to: weedseed85
    Nice to be able to pass on some of the help I have had over the years :smileyvery-happy:
    03-11-2013 07:01 PM in reply to: lesleys
    Do you know if RText can placed on 2 lines.
    the code that is being used is on 1 line the problem is when there are a number of xrefs the code runs off the page
    XREFS:$(xrefs,6,,/)
    Should I put this in a new post?
    Active Contributor
    03-12-2013 02:27 AM in reply to: craig.dunningham
    Diesel is not something I know about only what I have learnt from here.
    Try this
    $(xrefs,14)
    I have just tried this in a drawing that has 2 xrefs & it listed them one below the other which is I think what you are looking for.
    If that does not work you would probably be better as you suggest starting a new post with a different heading
    :smileyhappy:
