AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Rtext Diesel, cannoscale
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Dear autocad / lisp users,
Could somebody please help me.
I want to create a dynamic block that automaticly updates the viewport cannoscale a.k.a. Plotscale.
At the moment I / We have a dynamic block that contains a field for the Plotscale.
The only problem is, we have to fill it in ourselfs. so this means human errors or even blank fields.
Not so good.
Is there somebody who might knows a little bit of code to put in a RTEXT - Diesel block?
I will appreaciate anny help.
Thank you,
Michel
Re: Rtext Diesel, cannoscale
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Why not use a FIELD, and use the Viewport object properties?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for your post.
I've tried the field command, but with no luck.
When I put in a FIELD, and choose plotscale, it does not
update when I change the VpScale. It just stays 1:1
or a big numer in modelspace.
I tried several times before but, no luck.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try this it took me some time & help to get there, I think this is what J. Gerth is trying to tell you.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thats exactly what I was looking for!
Truely perfect
Thank you so much!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Nice to be able to pass on some of the help I have had over the years ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Do you know if RText can placed on 2 lines.
the code that is being used is on 1 line the problem is when there are a number of xrefs the code runs off the page
XREFS:$(xrefs,6,,/)
Should I put this in a new post?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Diesel is not something I know about only what I have learnt from here.
Try this
$(xrefs,14)
I have just tried this in a drawing that has 2 xrefs & it listed them one below the other which is I think what you are looking for.
If that does not work you would probably be better as you suggest starting a new post with a different heading
