• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Active Contributor
    Pertech-LLC
    Accepted Solution
    Right click Not working
    4023 Views, 6 Replies
    02-16-2011 12:04 PM
    All of a sudden I have no right click shorcut menu.
    Have checked Right click customization, and pickfirst command.
    shift+right click stil gets me osnaps, & right click on device (in electrical) gets me to edit device
    I'm Stumped !!
    Thanks!
    Please use plain text.
    *Pro
    nestly
    Re: Right click Not working
    02-16-2011 01:33 PM in reply to: Pertech-LLC
    No right-click menus at all, or no context sensitive right-click menus?
    Is "Shortcut menus in Drawing area" checked?
    Active Contributor
    Pertech-LLC
    02-17-2011 05:27 AM in reply to: nestly
    "Shortcut menus in drawing area" is checked.
    Not sure what you mean by context sensitive, but if I'm clicking on an item, it works. Also works if I'm using shift+rightclick, for Osnaps.
    Where its not working is just a plain right click in the model space, which used to bring up a shortcut menu. (properties, and options are the only two things I can think of offhand that are on that menu)
    *Pro
    nestly
    02-17-2011 05:56 AM in reply to: Pertech-LLC
    "Context Sensitive" means the menu options change based on what's selected.  ie there are different options on the right click menu depending on whether you select a line, or text, or a hatch etc.  But those seem to be working based on your last post, and it's the "default" right-click menu that's missing when you right click with nothing is selected.
    What is your SHORTCUTMENU variable set to?  (11 is the default setting for AutoCAD2011)
    Active Contributor
    Pertech-LLC
    02-17-2011 05:58 AM in reply to: Pertech-LLC
    "shotrtcutmenu" variable is set to 11
    Thanks again
    *Pro
    nestly
    02-17-2011 06:09 AM in reply to: Pertech-LLC
    I think I'm stumped.  Have you tried restarting AutoCAD?  Do you have a "Default Menu" listed in the CUI under the Shortcut Menus section?
    Active Contributor
    Pertech-LLC
    02-17-2011 06:38 AM in reply to: nestly
    You sir, are the MAN !
    To clarify for future searches:
    I was missing the "Default Menu" in my "ACade.cuix" .  I simply copied & pasted from my "ACad.cuix" file to the acade, & works great.
    Not sure as to why it wasn't there anymore, but that did fix my problem.
