• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    New Member
    Accepted Solution
    Ribbon empty
    326 Views, 2 Replies
    10-04-2012 09:03 AM
    When I start AutoCAD the ribbon is empty, nothing is displayed in it. It looks like this:
    If I click the A in the top left corner nothing happens, a menu is displayed when I do that on AutoCAD 2011 on the university computer. I'd like to practise what I learn at University at home but the program won't load the ribbon which makes it hard to do anything.
    I tried the "RIBBON" command but nothing happened. Changing the Workspace alters the size of the empty ribbon but nothing appears in it; Classic works but I do not know how to navigate the classic interface and am being taught using the ribbon interface at uni.
    Something seems to be wrong with the ribbon part of the program, I tried uninstalling and reinstalling but that didn't help. I have also turned all security programs on my computer off including windows defender + firewall.
    I am using AutoCAD 2011 Student Version 64bit. My computer is using an i5 3570K, 8Gb DDR3 1600Mhz RAM, HD6950 GPU and Crucial M4 SSD so is much faster than the required specifications. Everything else works fine on the machine so am at a loss for why the ribbon refuses to work.
    Could the file I downloaded be broken?
    Please use plain text.
    *Pro
    M_Hensley
    Re: Ribbon empty
    10-04-2012 11:42 AM in reply to: up652815
    Could be a graphics card issue. Do you have an Autodesk certified card and driver combo?
    New Member
    Re: Ribbon empty
    10-04-2012 01:18 PM in reply to: M_Hensley
    It was a driver issue, more specifically an issue with VirtuMVP by Lucid. It allows my on chip GPU to perform some tasks to help improve frame rate in games, and does a good job of that, but it seems that it is less than useful for AutoCAD.
    Once I disabled it everything displayed correctly. Thanks for the help.
