• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    KJack-Jack
    Rescale Command (2007 cog/utility command)
    118 Views, 2 Replies
    08-26-2011 09:31 AM
    I'm using AutoCAD 2011 working with a drawing created in 2007 or earlier. Is there a similar command that rescales blocks & text globally from their individual insertion points? I thought that 'annotation scale' would accomplish this but it rescales the whole vport.
    I know there has to be an easier way than selecting each font style/layer & block/layer to change their properties.
    Please use plain text.
    *Expert Elite*
    Patchy
    Re: Rescale Command (2007 cog/utility command)
    08-26-2011 09:40 AM in reply to: KJack-Jack
    SCALETEXT
    I don't think there is a command for block scale
    but you can use PROPERTIES, qselect BLOCKS and rescale
    *Expert Elite*
    08-26-2011 09:47 AM in reply to: KJack-Jack
    There maybe a lisp program to do that.  Do a search in the lisp forum, if you don't find anything then post a request.  Maybe someone there could write one for you.
