• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Distinguished Contributor
    Remove wipeouts
    460 Views, 8 Replies
    12-19-2012 08:08 AM
    Is there an easy way to remove all the wipeouts in a drawing without deleting the entities they are attached to?
    I have hundreds in some drawings, so I am trying to do a mass editing through lisp, but it won't remove just the wipeout, the text grouped with it gets deleted too. Any ideas?
    Please use plain text.
    Valued Contributor
    Re: Remove wipeouts
    12-19-2012 08:39 AM in reply to: cjneper
    Use combination Ctrl+H (or Pickstyle set to zero) then delete the wipeout.
    Re: Remove wipeouts
    12-19-2012 08:52 AM in reply to: cjneper
    Perfect!  Thank you.
    Member
    whorton-DK
    Re: Remove wipeouts
    12-19-2012 10:19 AM in reply to: cjneper
    Here is a small lisp routine I picked up somewhere which removes wipeouts
    (defun c:gowipe (/ b)
     (setvar "pickstyle" 0)
     (setq b (ssget "x" '((0 . "wipeout"))))
     (command "._erase" b "")
    Valued Contributor
    Re: Remove wipeouts
    12-19-2012 12:50 PM in reply to: whorton-DK
    Lisp is good but for something not doing everyday like deleting wipeouts
    Qselect, image, DELETE key wouldn't be that difficult.
    Valued Contributor
    Re: Remove wipeouts
    12-20-2012 01:35 PM in reply to: cjneper
    As easy as using the QSELECT command see image above and hitting the delete key after hitting ok on that dialog box. However if the wipeouts are embedded in blocks they won't be erased.
    pendean
    Re: Remove wipeouts
    12-20-2012 01:56 PM in reply to: Dave_S
    Let' count the ways....
    SELECTSIMILAR, found in a right-click or typed: simplest of them all. Everyone forget?
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    Valued Contributor
    bcinnv
    Re: Remove wipeouts
    03-04-2013 02:21 AM in reply to: cjneper
    wlhorton... You wouldn't happen to be in the vegas area would ya? Lol...that's the routine I wrote (exactly).
    - Brian
    "Very funny, Scotty. Now beam down my clothes."
    greg.battin
    Re: Remove wipeouts
    03-05-2013 07:48 AM in reply to: cjneper
    I just thought that I'd add one more tip in case someone can't select a wipeout to delete:
    Use TRFRAMES in the command line.
    This is a Toggle which means that simply running the command will either tuen it on or off. This toggle allows you to select Wipeout frames to be erased.
    Also shown [HERE]
    ~Greg
