AutoCAD 2010/2011/2012 DWG Format
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Regen in layout viewport does not work
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello everyone
My layers in layout viewport are displayed in wrong order even after I use REGEN or REGENALL command.
I am working with drawing file with quite big amount of layers (about 100+ including layers of 7 xrefs) and because I want to use different layer settings for each printed drawing I work directly in the layout viewports instead of model space so I don't have to switch on/off countless layers all the time. \
The problem is that quite often layers just turn into wrong draw order and don't come back even if I hit REGEN or REGENALL command. To solve this I have to zoom out, jump out of the viewport by doubleklick outside, use REGENALL command and then jump back to viewport so I can keep on working. This is extremely time consuming especially if it happens every 3 minutes, over and over again.
Does anyone have the same or similar problem? Maybe some tips for variables or settings to try? Thanks
Re: Regen in layout viewport does not work
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Read up on DRAWORDERCTL in help, and set SORTENTS to 51 (or 127).
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Seems to work perfectly, thanks ![]()
