• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    New Member
    Recover user settings and profile after Changing domain
    609 Views, 5 Replies
    03-29-2012 08:56 AM
    We had to migrate from one domain to annother on our network. This meant that each user had to create a new profile.
    Before we migrated I tried to back up the user data from the old user but once I am up an running agian all the AutoCad settings are no longer included. I understand you can export those while you are logged in and can see the macros etc. can you simply move the files that store that information (I can still access all the files from that user I just can't login as that user anymore)
    any assitance would be greatly appreciated.
    AutoCad 2011
    Jeff
    Please use plain text.
    Product Support
    Volker_C
    Re: Recover user settings and profile after Changing domain
    04-03-2012 07:21 AM in reply to: jwheeler
    The settings for the user are in the registry but most of the user defined files for AutoCAD can be found in the following folders, some of which may be empty depending on what tools were used.
    Windows 7 -->> C:\Users\<username>\AppData\Roaming\Autodesk\AutoCAD 2011\R18.1\enu
    Windows XP -->> C:\Documents and Settings\<username>\Application Data\Autodesk\AutoCAD 2011\R18.1\enu
    AssetLibrary
    Data Links
    LanguagePack
    Materials
    Migration
    Plotters
    Recent
    Support <----------------------- Primary folder for user customization files (Menu files, Linetypes, acad.pgp). This folder also contains sub folders for tool palettes and Icons.
    Windows 7 -->> C:\Users\<username>\AppData\Local\Autodesk\AutoCAD 2011\R18.1\enu
    Windows XP -->> C:\Documents and Settings\<username>\Local Settings\Application Data\Autodesk\AutoCAD 2011\R18.1\enu
    LanguagePack
    Support
    Template
    WebServices
    I hope this helps.
    Volker
    Please let us know if your questions have been answered by selecting, "Accept as Solution"
    Volker Cocco
    Support Specialist
    Product Support
    Autodesk, Inc.
    New Member
    04-03-2012 10:43 AM in reply to: Volker_C
    Thanks for the Reply I will let you know how it works.
    Product Support
    Volker_C
    04-09-2012 03:26 PM in reply to: jwheeler
    I just wanted to check if this had been resolved. If so, please let us know.
    Cheers!
    Volker
    Volker Cocco
    Support Specialist
    Product Support
    Autodesk, Inc.
    Product Support
    Volker_C
    04-12-2012 10:15 AM in reply to: Volker_C
    I'm wanted to check if you had any feedback for us.
    Volker
    Volker Cocco
    Support Specialist
    Product Support
    Autodesk, Inc.
    New Member
    10-12-2012 01:08 PM in reply to: jwheeler
    so what do we need to do to get the program to function when the user is logged into the new domain?
