• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    New Member
    ali136
    Read only
    271 Views, 5 Replies
    01-10-2012 03:16 AM
    Hi
    I was working with CAD 2011 for a long time and it was working like charm.
    But from about 2 weeks ago While I'm working suddenly file becomes read only and I have to make a copy
    how can I fix it ?
    Please use plain text.
    pendean
    Re: Read only
    01-10-2012 05:27 AM in reply to: ali136
    wireless connection to the file location by chance?
    Or a failing wired connection?
    A loss of access to the file by AutoCAD tends to make the program assume someone else have the file open and it tags the file as read-only.
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    New Member
    Re: Read only
    05-18-2012 01:59 PM in reply to: ali136
    I also have a problem with files saving as "read only" unprompted. I will be as much help as the AutoDesk forums because I have no solution.  Copying the file from the server to my desktop, working on it, then copying the file back to the server has curtailed the read only problem but it doesn't fix it. This is bad for the design process because it often results in multiple files with multiple changes from multiple users. Autodesk tech support is super helpful, it tells me to contact my Contract Manager, so I click on that, and wouldn't you know it, it's my boss Larry. Turns out Larry has no idea what I'm talking about and wants to send me to El Salvador. I wonder if Bentley is this good at support. Another thing: Who gets up in the morning and says "I'm gonna go answer some questions in the forum today." Good luck, and emoticon.
    pendean
    Re: Read only
    05-18-2012 02:12 PM in reply to: KKernLRDG
    This fact has not changed yet:
    "A loss of access (or connection) to the (DWG) file by AutoCAD tends to make the program assume someone else has the file open and it tags the file as read-only."
    Distinguished Mentor
    thepworth
    Re: Read only
    05-18-2012 02:30 PM in reply to: KKernLRDG
    Actually, a few of us are perverse enough to troll the forums....
    WHen you open a drawing, ACAD creates a .DWL file, or a drawing lock, in the drawing's directory.  If you loose network access, the .DWL isn't automatically erased like it is when you close "normally"  Reopening the drawing sees the DWL and assumes that the lock means the drawing is in use.  Hence Pendean's answer......
    So, is the issue a loss of connectivity and/or crashing out of a drawing, or is it happening every time you try to open a drawing?  I need more information to help you any further.
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    thepworth
    Re: Read only
    05-18-2012 02:30 PM in reply to: thepworth
    Oh, and try deleting the .DWL file - you should see the "read only" go away....
    C3D 2011
