• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD 2010/2011/2012 DWG Format
    Active Member
    Purging Unused Blocks
    648 Views, 5 Replies
    04-02-2012 12:37 PM
    Situation:
    I’m currently cleaning up an old file that is rather large. (so large I cant xref anything with out AutoCAD crashing)
    Problem:
    There are way too many “blocks” in the file, about 700 in all. Of these 700, more then 600 of them aren’t even being used anymore.
    Question:
    Is there a way to purge out unused blocks?
    Thanks for the help.
    Please use plain text.
    Re: Purging Unused Blocks
    04-02-2012 01:03 PM in reply to: JoeMin
    Yes, just use the PURGE command.
    Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
    jonmcfarlandWS
    04-02-2012 01:05 PM in reply to: JoeMin
    Joe,
    Type PURGE, check the Purge Nested Items option and uncheck Confirm each item to be purged options in the Purge dialog box, then click Purge All.
    Jon
    Jon
    Please select "Accept as Solution" if your question was answered.
    curtainwallBIM.blogspot.com
    Distinguished Mentor
    thepworth
    04-02-2012 01:35 PM in reply to: JoeMin
    Also,
    Use "-PURGE" and "R" for regapps - at least with C3D the unused / unnecessary regapps can really bloat a drawing - such as from 600KB to 3MB....
    Best of Luck!
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    heinsite
    04-02-2012 04:01 PM in reply to: vladimir.michl
    And don't be afraid to run it more than once.  The first time PURGE can reveal nested blocks but not remove them.  A second, or subsequent PURGE, will be needed to get rid of them.
    Dave.
    Dave Hein, P.E.
    Active Member
    04-03-2012 05:06 AM in reply to: JoeMin
    Ya, im realy rusty with AutoCAD, compleatly forgot about the purge command. i did it a few times, made most of the files go from 6,700 KB to arou 1,000 to 175 KB.
    thanks for the help guys.
