AutoCAD 2010/2011/2012 DWG Format
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Punched-ou t region question
- Highlight
- Email to a Friend
Good morning, all.
I've never tried this in AutoCAD before, so that is why I've come to the experts here for help. I would like to create a simple rectangular area with a circle in its center. When this area is hatched, the circle is hollowed out. Furthermore, I'd like to have this to insert into a block for stretch action manipulation. Is this possible with AutoCAD 2010?
Thank you all.
Chris Martin
Re: Punched-ou t region question
- Highlight
- Email to a Friend
should be possible, haven't you tried it?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
- Highlight
- Email to a Friend
I have tried the Region command, but only for a few moments. And each time I tried, the command created two regions (the rectangle, and the circle). These remained separate to themselves; I could not figure out how to combine them, especially since the two elements do not intersect at any point.
Thank you.
Chris Martin
- Highlight
- Email to a Friend
Don't use region, use command _RECTANG for rectangle as polyline, then draw a circle and last but not least create the hatch.
- alfred -
Alfred NESWADBA
- Highlight
- Email to a Friend
Pardon me, sir, but I feel that you misunderstand what I am asking about.
I need to display a solidly filled rectangle area, and if the rectangle was a piece of paper, the circle would be a punched-out hole in its center. Wipeouts can do this, but only for linear polylines (no arcs). That is why I am asking about regions.
Chris Martin
- Highlight
- Email to a Friend
if so then sorry, but I give it an additional try.
If that is also wrong, then at least it helps that you can then describe what you don't like here.
- alfred -
Alfred NESWADBA
- Highlight
- Email to a Friend
That is your idea?
- Highlight
- Email to a Friend
Dear Mr. Neswadba,
I took a look at your file. Thank you for it. I managed to get close to what you had before I began this thread. It appeared that I was not properly grabbing points & handling parameters when I dealt with the hatching. I have now accepted your thread as the solution, and you have my thanks.
Chris Martin
(A note to User sancdub: you were also on the same track as Mr. Neswadba and I. Thank you for your input also.)
