• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD 2010/2011/2012 DWG Format
    Valued Contributor
    Punched-out region question
    396 Views, 7 Replies
    01-10-2013 08:21 AM
    Good morning, all.
    I've never tried this in AutoCAD before, so that is why I've come to the experts here for help. I would like to create a simple rectangular area with a circle in its center. When this area is hatched, the circle is hollowed out. Furthermore, I'd like to have this to insert into a block for stretch action manipulation. Is this possible with AutoCAD 2010?
    Thank you all.
    Chris Martin
    Please use plain text.
    Re: Punched-out region question
    01-10-2013 09:05 AM in reply to: Spiritshifterus
    should be possible, haven't you tried it?
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    01-10-2013 09:11 AM in reply to: alfred.neswadba
    I have tried the Region command, but only for a few moments. And each time I tried, the command created two regions (the rectangle, and the circle). These remained separate to themselves; I could not figure out how to combine them, especially since the two elements do not intersect at any point.
    Thank you.
    Chris Martin
    01-10-2013 09:19 AM in reply to: Spiritshifterus
    Don't use region, use command _RECTANG for rectangle as polyline, then draw a circle and last but not least create the hatch.
    - alfred -
    Alfred NESWADBA
    Valued Contributor
    01-10-2013 09:26 AM in reply to: alfred.neswadba
    Pardon me, sir, but I feel that you misunderstand what I am asking about.
    I need to display a solidly filled rectangle area, and if the rectangle was a piece of paper, the circle would be a punched-out hole in its center. Wipeouts can do this, but only for linear polylines (no arcs). That is why I am asking about regions.
    Chris Martin
    01-10-2013 10:05 AM in reply to: Spiritshifterus
    if so then sorry, but I give it an additional try.
    If that is also wrong, then at least it helps that you can then describe what you don't like here.
    - alfred -
    Alfred NESWADBA
    New Member
    01-10-2013 11:09 AM in reply to: Spiritshifterus
    That is your idea?
    Valued Contributor
    01-11-2013 07:40 AM in reply to: alfred.neswadba
    Dear Mr. Neswadba,
    I took a look at your file. Thank you for it. I managed to get close to what you had before I began this thread. It appeared that I was not properly grabbing points & handling parameters when I dealt with the hatching. I have now accepted your thread as the solution, and you have my thanks.
    Chris Martin
    (A note to User sancdub: you were also on the same track as Mr. Neswadba and I. Thank you for your input also.)
